Question about charging with SuperREG
Hi, I recently purchased a system from you and have a question. Current plan:
Batt_1>SuperSwitchHD_1>SuperREG_Input_1>PowerExpan derSport_Input_1
Batt_2>SuperSwitchHD_2>SuperREG_Input_2>PowerExpan derSport_Input_2
Will these batteries have a common ground? I know my current charger, Accucycle Elite, has a problem with common ground charging. Thanks in advance!
AZ
RE: Question about charging with SuperREG
Hi,
Yes, you will end up with a common ground. Any time you plug two batteries into a single destination you will always end up with a common ground system. No switch I know of switches the ground lead, they all switch the positive lead only. To have a reliable system you have to have all the grounds tied together. I know of no way around this.
Let me know if you have any futher questions.
