Smart-Fly (Quest Engineering) Support Forum Support forum for all Smart-Fly products. Equalizers, Batshare, Ignition Cutoff, Regulators.
Super Regulator
Reply
Old 11-02-2007, 08:29 AM
juanes1969
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Super Regulator
Robert:
I just wanted to know, if the super regulator has 7.5 Amps max continuos current, what is the peak current?
John
juanes1969 is offline
Old 11-02-2007, 09:11 AM
rrritchey
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Super Regulator
Hi John,
The peak current is a little hard to set a definitive number on. The transistor can handle 40 amps but it has a 0.025 ohm resistance fully turned on which means you would get a 0.5V drop across the resistor at 20 amps. So, if you were down to 7.0V on your lithium batteries and took into account the 0.44 volt drop across the BatShare in the SuperReg then you could pull 20 amps without causing the regulator to drop under a regulated voltage of 6.0V. If you did not care if the output dropped below 6.0 volts some then you could do more than 20 amps.
I hope this helped. Let me know.
rrritchey is offline
Contact Us Archive Advertising Cookie Policy
