Damaged PE
My Feedback: (44)
CA
Damaged PE
Dear Sirs,
My 50 cc Yak recently experienced radio problems that caused a crash. Onboard was your Smartfly PE. Upon inspection I found that one of the LED's (LED1) had broken off of the main PE board. Should this damage be a concern to me? If so can if be repaired?
Wayne Titterington
Wayne Titterington
AZ
RE: Damaged PE
Hi Wayne,
This should cause you no operating problems. I am sure the unit could be repaired. It would probably cost around $20 including the labor, parts and return postage. This is a guess but if that is the only damage I think it would be close.
