Smart-Fly (Quest Engineering) Support Forum Support forum for all Smart-Fly products. Equalizers, Batshare, Ignition Cutoff, Regulators.
50CC Composite ARF what regulator?
Reply
Old 03-17-2008, 11:56 AM
ravikoth
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default 50CC Composite ARF what regulator?
hi,
I am currently building a DA50 Powered 78" wingspan composite arf extra. I am using 6 Hitec Digital servos Model HS 5645MG.
I am also using a Spektrum AR9000 Reciever, as i understand that the spektrum gear is voltage sensitive, i plan to use 2 Thunder power 2cell 2100 mah lipo packs through 2 regulators and 2 switches into the 2 battery ports in the reciver.
However i saw your Sport regulator & the Super regulator. considering my setup what should i do,
1) Run 2 seperate regulators & switches
OR
2) Run both the lipo packs through 2 heavy duty slide switches through the dual regulators mentioned above. And if so. then considering my setup, which of the 2 regulators would you recommend.
Please advise.
Thank you & Regards
Ravi Kothari,
Mumbai,India.
BTW i am ready to place my order with Airwild, just waiting for your input here.
ravikoth is offline
Old 03-17-2008, 12:07 PM
rrritchey
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: 50CC Composite ARF what regulator?
Hi Ravi,
The SportReg and SuperReg are not "dual regulators". They support dual batteries but are a single regulator. Your choices are really personal choices on how you feel about redundancy. We feel battery redundancy is most important because we feel a regulator should be very reliable, as much so as your receiver. Some people want the extra insurance of two regulators. The down side to this is that the batteries on each regulator will go down different amounts, regulators do not share current equally when they are connected together. If you want to run one of our dual-battery regulators then for your size plane I would recommend the SportReg.
rrritchey is offline
Old 03-17-2008, 12:12 PM
ravikoth
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks for that,
however have you had any cases of a regulator go bad, also i know it is a personal choice, but what would you Do?
Regards
ravi
ravikoth is offline
Old 03-17-2008, 12:16 PM
rrritchey
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Ravi,
If you are worried about that then you should run two regulators.
Contact Us Archive Advertising Cookie Policy
