If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Results 1 to 4 of 4
  1. #1
    InboundLZ's Avatar
    Join Date
    Oct 2004
    Las Vegas, NV
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    JR 2.4 / SmartFly issue ***HELP***
    Guys,
    Was working to rig my KC last night and I am having a horrible time with the flaps. The system is wigging out....here is what I have installed:
    JR / Spectrum AR9000 DSM2 9 Ch RX
    Smart Fly EQ10
    2 Ea. 2S A123 batteries
    JR PCM10X with 2.4 module
    2721 Servo
    The issues are:
    Flap servo jitters violently at various times and requires the system to be shut down to restore normal operation
    Flap servo appears not to have the ability to hold a given flap position with any degree of force. Surface can be easily deflected by light hand pressure.
    Servos DO NOT jitter when being driven buy a external servo driving device, they only operate violently when powered via EQ10.
    I was convinced that I needed to buy new servos, now I am not so sure.
    Does anyone have any idea what my next move should be?
    TIA.
    Dave Bottita
    Jet Cat Factory Pilot
    JR America Team Member
    Smart-Fly
  2. #2
    Join Date
    Sep 2004
    Tempe, AZ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: JR 2.4 / SmartFly issue ***HELP***
    ORIGINAL: F-18DiamondBack102
    Guys,
    Smart Fly EQ10
    2721 Servo
    The issues are:
    TIA.
    You might be having an issue with these servos that people used to have with 5-cell nickel packs were the signal voltage (3.3V) is just barely too low for the servo when its power at 7.2V. Then again it might be something else. When you drive the servo with the external servo driver is it running the servo at 7.2V or something around 5.0V? If you contact me I can send you a replacement to see if it helps or not.
    Robert Ritchey
    Owner, Smart-Fly
    www.Smart-Fly.com
  3. #3
    InboundLZ's Avatar
    Join Date
    Oct 2004
    Las Vegas, NV
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Robert,
    Thanks for the quick reply.
    I am not sure about the voltages as it relates to signaling. What I do know is I am running this exact same setup with the exception of the servo in my Γ‰lan and have no issues whatsoever. I am not convinced that the EQ10 is the issue at this point as my experience with them has been excellent to this point. I am going to remove the EQ10 from the system and drive one flap servo directly off the RX.
    As far as the external driver for the servo I am using a 4.8 RX pack to run that system.
    My gut is telling me it is the Servos.....
    Dave Bottita
    Smart-Fly
  4. #4
    Join Date
    Sep 2004
    Tempe, AZ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Robert,
    Let me know if you want to try a new one. No problem sending you one.
    Robert Ritchey
    Owner, Smart-Fly
    www.Smart-Fly.com
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
