Smart-Fly (Quest Engineering) Support Forum Support forum for all Smart-Fly products. Equalizers, Batshare, Ignition Cutoff, Regulators.
14MZ battery charging
Reply
Old 09-10-2008, 09:10 PM
Dean@XC
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default 14MZ battery charging
There are two ports labeled charge which I assume is to charge two batteries. How can this work as there will be a switch between the batteries and the Smart Fly.
Regards Dean
Dean@XC is offline
Old 09-11-2008, 08:54 AM
rrritchey
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: 14MZ battery charging
Hi Dean,
The charge ports are used when you use the failsafe switch instead of mechanical switches. When the failsafe switch is used, both batteries are connected directly to the unit, no mechanical switches. The failsafe switch plugs into a special port and turns on/off both batteries. Since you have no mechanical switches in this case, the charge ports are the only way to charge the batteries. When you use mechanical switches you would use the charge port in the switch and the MZ charge ports would not be used. Please let me know if you have any other questions.
rrritchey is offline
Old 09-11-2008, 10:02 AM
Dean@XC
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Robert,
Does the fail safe switch look the same as the HD switch? I cannot seem to find a view of it on your website.
Regard Dean
Dean@XC is offline
Old 09-11-2008, 10:09 AM
rrritchey
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Dean,
There is a picture of the Pin & Flag failsafe switch by the PowerExpander Pro. We also have a small slider switch, no charge jack, kind of like what normally comes with a radio.
Old 09-11-2008, 01:17 PM
Dean@XC
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks for your quick response.
Regards Dean
Dean@XC is offline
Contact Us Archive Advertising Cookie Policy
