Smart-Fly (Quest Engineering) Support Forum Support forum for all Smart-Fly products. Equalizers, Batshare, Ignition Cutoff, Regulators.
good protection 6014FS
Reply
Old 11-06-2008, 05:50 PM
Hughes500E
Hughes500E's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default good protection 6014FS
Greetings
I am putting together an Extreme Flight 88 inch Yak 54 with a 57 size gas engine. I am currently running Duralite's Lithium Ion 4 cell 7.4 volt 4300 Mah redundant batteries with a switched fail safe 7.5 Amp regulator @ 6 volts powering Hitec's 5955 servos. I want to switch to Futaba's 6014FS 2.4 Ghz receiver for 2048 res. Can I just simply run the power expander sport with the listed equipment and be safe from the 2.7-2.8 volt concerns connected to the 6014FS?
Many thanks
Hughes500E is offline
Old 11-06-2008, 05:54 PM
rrritchey
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: good protection 6014FS
Hi,
Actually, all 2.4GHz receivers have a reset problem because of the nature of the technology, but in short yes. As long as the input voltage to the PowerExpander sport is above 4.0V you should have no problem. Running a SuperReg and your batteries you will not have an issue. Let me know if you have any other questions.
rrritchey is offline
Reply
Display Modes
