A123 rx ign thru battshare
Hi Robert, trying to configure a 50cc (5625 x4 + 5745 x1) with the following:
2300 a123 2s1p - switch - batshare (lead 1) - rx
2300 a123 2s1p - switch - batshare (lead 2) - switch - ignition (DL50 rexcel oct-08 ignition)
will charge each a123 from switch, one at a time.
thoughts?
Etham.
thoughts?
Etham.
AZ
RE: A123 rx ign thru battshare
Hi Etham,
We really discourage running the receiver and ignition off the same power source. If anything goes wrong in the ignition the amount of noise if can generate can swamp out any receiver, including 2.4GHz (2.4GHz receivers are NOT immune to noise, you have to take the same precautions with them as with 72MHz receivers).
