Smart-Fly (Quest Engineering) Support Forum Support forum for all Smart-Fly products. Equalizers, Batshare, Ignition Cutoff, Regulators.
Power system and regulator question
Reply
Old 05-29-2009, 04:58 PM
dingo9882
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Power system and regulator question
Fella's this is a technical question that I am having a little problem trying to figuer out. I have a Top Flite Giant P-47 that is running 10 servos. This includes all Hitec servos consisting of:
5 5645 Digital MG servos- Rudder, ailerons, elevators
2 5245 digital MG servos- throttle and cutoff
1 HS-82- Retracts
2 645 MG - Flaps
I will be running it off of 2, 21007.4volt lipos with a 9 channel synthasized reciever. My question is this:Which regulator should Ichoose with this configuration?Iwill also be regulating it down to around 5.9 or 6.0 volts. Now I have done the math and I just cannot tell if this is going to work out. Maybe you guys can check my math as well and help me make a decision onto which regulator I should buy.
Now if you guys have a completely different suggestionI am open to it. Reason why I say that is because people are also recommending the power systems. But, just like the last question...which one should I choose for this application.
thanks for any help
Chris
dingo9882 is offline
Old 05-29-2009, 05:14 PM
rrritchey
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Power system and regulator question
Hi Chris,
I would recommend you use the PowerSystem Sport or Sport Plus (I don't know if you are running gas or glow).  This will regulate and provide the 6.0V to your servos from the lithium cells.  Since the regulator is built into the unit you will see no voltage drop at any of the servo outputs no matter how much current the other servos may want.
You can of course run a regulator into your receiver.  You did not say how heavy a plane this will be, sorry I am not up on the sizes of all these planes.  I am guessing a SportReg will handle your plane but I need to know more about the weight and engine.
rrritchey is offline
Old 05-30-2009, 05:52 PM
dingo9882
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The plane will be weighing in at around 25 or 26 pounds and I will be running a gas engine on it around the 70 to 80 range. I hope this helps. If you recommend something else that would be great.
Old 05-31-2009, 03:33 PM
rrritchey
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Chris,
Unless you are going to be really throwing this plane around the sky the PowerSystem Sport Plus should work just fine.  If you just want to go with a regulator the SportReg or SuperReg will work for you.  Let me know if you have any other questions.
Old 06-01-2009, 05:54 AM
dingo9882
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I forgot to say one more thing...I will be using two futaba synchronizers as wel...will the PowerSystem Sport Plus still work with these.
Old 06-01-2009, 08:37 AM
rrritchey
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Chris,
Yes, we will work with the Futaba MSA10s.  If you have not bought these yet you might check out our Equalizers.
Contact Us Archive Advertising Cookie Policy
