PowerSystem Sport Plus
Hello, I have a Futaba R6008HS, five JR8611A, a JR126MG and I wonder if it is correct to use the PowerSystem Sport Plus.
The regulator is sufficient for the consumption of my servos?
Thank you very much. Greetings.
Guillermo.
Guillermo.
AZ
RE: PowerSystem Sport Plus
HI Guillermo,
Its more a question of plane size than servos. The PowerSystem Sport Plus is recommended for anything up to 85cc that has single servos on each aileron, this includes biplanes. It can handle planes up to 18 lbs or so. We can handle any size servo you feel like putting in this size plane.
AZ
Hi,
Yes, the PowerSystem Sport Plus only buffers the signal so what ever comes out of the receiver will come out of the servo port. The PS-Eq6 and PE-Eq10 will only update at 60Hz always.
AZ
Hi,
We do not recommend it. Its bigger, heavier and has more power, you will put a strain on the unit. We specified a maximum size of 85cc, single servo per wing to give a comfortable margin.
