Smart-Fly (Quest Engineering) Support Forum Support forum for all Smart-Fly products. Equalizers, Batshare, Ignition Cutoff, Regulators.
Batshare 2nd output + MatchBox
Reply
Old 09-19-2009, 10:38 AM
Vaccari
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Batshare 2nd output + MatchBox
Hello, has anyone had a similar problem?
One of my SM Batshare outputs is going to my AR700 Rec. batt input, but I do not have an extra servo port to put the second Batshare output.
Can I plug this second Batshare output in the JR Matchbox that I'm using for the ailerons?
If I can, should I use the AUX/BATT port or one of the other remaining ports?
My setup consists of 2 A123 6.6 - 2 switches - Batshare - (one output to the Batt/Data AR 7000 Rec. port)
5 JR 8711 + 2 JR 821
DA 50cc
Regards,
Marcelo
Vaccari is offline
Old 09-19-2009, 12:44 PM
rrritchey
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Batshare 2nd output + MatchBox
Hi Marcello,
If you do not have a second open port on your receiver you can "Y" it in with one of your servo outputs. I think this is the best way to go.
rrritchey is offline
Old 09-19-2009, 12:57 PM
Vaccari
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thank you Ritchey.
Marcelo.
Vaccari is offline
Old 10-05-2009, 06:49 PM
Vaccari
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hello Ritchey,
I used an "Y", as you described but the servo went kind of crazy, not respondind properly, looked like it was on "tilt". The Y extension was on of those JR with amplifier. I took it off and the servo worked fine. It was a JR 821 that I used for the choke. I flew the plane like that, but would like to know if I really need to plug the second line in another port. Or do you think the problem was the amplifier Y?
Regards,
Marcelo.
Vaccari is offline
Old 10-06-2009, 09:52 AM
rrritchey
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Marcelo,
You should not "Y" into a channel that uses an amplifier. Only "Y" into a channel that goes straight to a servo. You can fly it without the "Y" but your receiver bus voltage will drop when your servos what heavy currents.
Old 10-06-2009, 10:16 AM
Vaccari
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Actually, none of my channels use an amplifier. The JR Y extension has an amplifier itself. If I use a plain Y extension you think I will be alright?
Regards,
Marcelo.
Vaccari is offline
Old 10-06-2009, 10:28 AM
rrritchey
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi,
The "Y" amplifiers only work when the output of the receiver is close to the actual battery voltage. You cannot use these with Futaba receivers and JR or Spektrum 2.4GHz receivers. They are just problematic in general. I recommend against using them is there is any way not to. Try using a plain "Y" extension.
Old 10-06-2009, 12:44 PM
Vaccari
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Ok, I will do that.
Thank you again for your help.
Marcelo.
Vaccari is offline
Contact Us Archive Advertising Cookie Policy
