Smart-Fly (Quest Engineering) Support Forum Support forum for all Smart-Fly products. Equalizers, Batshare, Ignition Cutoff, Regulators.
EQ6 transistor temperature
Old 10-07-2009, 03:51 PM
My Gallery
My Models
My Feedback
Default EQ6 transistor temperature
Hello, in the EQ6 manual says that the transistor can reach 175 degrees, this high temperature can get to where the receiver is located? because it could cause failures in the Futaba Fasst.
Thank you very much. Greetings.
Guillermito is offline
Old 10-07-2009, 04:06 PM
My Gallery
My Models
My Feedback
Default RE: EQ6 transistor temperature
This is the temperature of the heat-sink. It will not affect the operation of the FASST receiver. The heat-sink getting this hot would mean you are pulling 7.5 amps continuously for several minutes. This should not happen under any circumstances any way, but this will not heat up the inside of your plane to the point the receiver will overheat. Your headers are more dangerous than the regulator heat-sink. The receiver should mount as normal on the unit or on a receiver mount. There will be no issues.
rrritchey is offline
Display Modes
Contact Us Archive Advertising Cookie Policy
