how to install Superreg
Hi all,
just finishing my EF 88'' yak, and installing now the Superreg. just want to know if it is possible to install the Superreg by using foam and dual adhesive band on the back ? then a velcro strap all arround. there is no need for airflow on the back ? i'm right . thanks for feedback Michel |
RE: how to install Superreg
Hi Michel,
The back is very thin plastic. Just about any force will fracture it. It was not designed to support the unit. Unless you wrap the unit VERY loosely you will probably crush the back. I really recommend using the grommets for mounting. |
