Go Back  RCU Forums > RC Boats > Speed - Electric
Reload this Page >
widow maker esc ?
Speed - Electric For all your electric boating needs.
widow maker esc ?
Old 02-20-2011, 05:19 PM
bruce5385
Default widow maker esc ?
bought this boat for my son and just wondering what esc i should put in it. the esc was bad when i got it and picked the boat up really cheap. thanks
Old 02-21-2011, 02:51 PM
bruce5385
Default RE: widow maker esc ?
anyone?
Old 02-21-2011, 04:11 PM
Diesel6401
The stock esc in these boats (and the sw26s) are straight junk..... A small seaking should be a nice positive upgrade http://www.hobbycity.com/hobbyking/s...idProduct=7377
Old 02-21-2011, 05:07 PM
bruce5385
thanks thats the one i was thinking about getting. new to the electric side of boats
Old 02-21-2011, 05:58 PM
Diesel6401
The turnigy marine esc's are re-branded hobbywing seaking. The are a great bang for the buck. I run the seaking 120s and 180 and have great success with them. Another place is hobbypartz and they normally have free shipping and you usually get the parts in 3-5 days which is a lot quicker then the china warehouse of HK. HK's USA warehouse is pretty fast though. This is the exact same esc that HK sells, just not re-braneded...http://www.hobbypartz.com/07e-c-seaking-35a.html
ORIGINAL: bruce5385
Old 02-21-2011, 06:47 PM
djr01974
What's a good brushless motor to go with the seaking esc.
Old 02-21-2011, 07:15 PM
Diesel6401
For this hull or a different hull? Problem with the widowmaker is the stock location of the motor is wrong should be more aft and the hull doesn't handle much speed very well or turn very well for that matter. Theirs only 1 guy I have read that has this hull running well and did A LOT of work to get it running that way. With all that said the stock motor and this esc will be fine together. If your talking about a different hull you will need to add more information to get a accurate answer...
ORIGINAL: djr01974
Old 02-21-2011, 08:53 PM
djr01974
For the apache 24 hull.
Old 02-21-2011, 09:25 PM
Diesel6401
Some people have converted those hulls to brushless in the past. The hull wasn't ever really designed to run that fast so it can be unstable, but you can make it work. I have the same boat except I converted mine into a rescue boat to safe my downed brushless boats, that was the best thing I ever did with that hull. All I did was change the stock esc out to a better brushed one and slapped $10 worth of pvc to the front of it and damn I love that thing. Has saved my butt a few times.
Try reading through this and you may find a good setuphttp://forums.offshoreelectrics.com/...splay.php?f=31
ORIGINAL: djr01974
Old 05-29-2014, 10:46 PM
Lightning Bolt
I just picked a Widow Maker up and need a battery ... any recommendations?
