what to do with this lipo
I have a 4s1p 5000 mah 20-30 c lipo battery. only has about 7 cycles on it but in my stupidity i short circuited it and now cell 3 is reading dead. Options i was considering. De solder the faulty cell from the board and charge it seperately so that if it does puff or catch on fire it doesn't destroy the 3 working cells and then i'd be able to get a pcb board from radio shack and just make a 3s cell or if it successfully takes the charge i could just put it back in the 4s configuration. Or do i just try to charge that cell individually with it how it is and if it takes it, i'm good to go and if it doesn't then i scrap it.
WHAT WOULD U DO?
WHAT WOULD U DO?
NC
RE: what to do with this lipo
* If it's a turnigy or a zippy I would just cut my losses but if its a high grade pack TP, hyperion ect I would try my hardest to safe something on it lol....
found out the cell actually wasn't dead. All it was was the tab coming out the + side of that single cell. It vaporized when i shorted it so i soldered it up and now i'm getting a good voltage reading. I am going to cycle it a couple times before it makes it's way back into the boat though.
i know cause it the tab was still on the board really good. Didn't discover it until i tried charging it and the charger just said connection break. Still makes me a little nervous though. I had to trim some of the foil like stuff the cells are in cased in to reveal a little bit more of the tab. All the actual seals are still good though, i just trimmed the excess.
