Go Back  RCU Forums > RC Boats > Speed - Electric
Reload this Page >
29" build complete
Speed - Electric For all your electric boating needs.
29" build complete
Old 03-23-2011, 02:29 AM
LENYLOW
Default 29" build complete
Hi all just thought i would share some pics of my 29" mono now it is finished.
i shall be giving it a test run hopefully at some point over the weekend.
i have set it so that the lipos can be mounted in verious diffrent positions
down the sides, or horizontaly or straight down the middle.
ID:	1582872   Click image for larger version
ID:	1582873   Click image for larger version
ID:	1582874   Click image for larger version
Old 03-23-2011, 05:12 AM
Dirt_hawg
Default RE: 29
Nice build..Id like to have a mono about like that..what does a setup like that cost?
Have fun!!
Old 03-23-2011, 02:40 PM
LENYLOW
Default RE: 29
It depends what you have allready got, the hull was $60 on ebay, its a copy of the d/f 29 and apart from
some epoxy thats all its cost me. The parts and hardware i have just switched straight across from one of
my sv27 hulls.
Old 03-26-2011, 03:29 PM
LENYLOW
Default RE: 29
Took it for its first run today, it all went quite well, realy good cornering, no leeks etc.
The only thing is the top speed was not all that great, it was only reading 40mph on the gps.
I was expecting it to be mid 40s atleast as thats what i was getting with the sv27 hull.
Would this be beacuse the hull is slightly larger? it was running slightly wet so i have adjusted
the strut up a fraction. It has the ul1 6pole 2030 motor, and swordfish esc on 4s.
Old 03-26-2011, 04:01 PM
BACKEMF
BACKEMF's Avatar
Default RE: 29
What size prop? 40 is about right on a carbon prop. Get an M545 SBP & you should get better speed.
Bettter cells like Nano tech may increase your speed too.
Old 03-26-2011, 04:25 PM
LENYLOW
Default RE: 29
I was using a carbon 45mm. so it may be best to start smaller? i have a 40 and a 42 that i can try.
Is the m545 an octura?
Old 03-26-2011, 04:27 PM
BACKEMF
BACKEMF's Avatar
Default RE: 29
A K45mm sounds good but to get more speed you could try a metal prop like the Octura M545, even an M445 will be better than a K45.
How fast do you expect to go?
Old 03-26-2011, 04:33 PM
LENYLOW
Default RE: 29
I would like to get into the high 40s with it realy, i would be happy with that. I will look
into getting one of the octura props that you have mentioned, i did give a 440/3 a go but
that was slower than the k45. plus i would rather just stick to two blade props.
Thanks for your help.
Old 03-28-2011, 11:04 AM
srt10
My Feedback: (20)
Default RE: 29
The Octura M545 and M445 are two blade props that would help out over k prop like what was posted above
another to try would be the X645
great use of SV hardware by the way
Old 03-28-2011, 08:46 PM
losifiend
Default RE: 29
Nice boat!
Is that a UL1 motor? I would run a $60 4074, 2150kv Tacon motor with an x445 or x447 prop and hold on!
Old 03-31-2011, 08:31 AM
LENYLOW
Default RE: 29
Yes it was a ul-1 motor, it has started making a nasty grinding noise now after todays run, so i guess
thats had it. so am now looking at a new motor so will check the one out you suggested.
Old 03-31-2011, 10:18 AM
srt10
My Feedback: (20)
Default RE: 29
ORIGINAL: LENYLOW
soak that motor with some WD40 and see if that helps smooth things out again
it will also help to water proof it
Old 03-31-2011, 01:23 PM
LENYLOW
Default RE: 29
I have taken the motor out and it turns but is realy tight, It was running fine, then it hit some
chop witch made the boat jump and it was when it landed that it happend. I thought at first
that i had lost a blade on the prop.
