What Prop size?
What Prop size?
<meta charset="utf-8" />I need to find a good propeller for a custom boat I am making. I will be using this motor:http://www.offshoreelectrics.com/pro...rod=fei-380-xL
I am open to suggestions for KV
And I will be using it in a pretty tubby 20 inch balsa wood boat. I need to find a good propeller to use with it.
I was looking at this one
http://www.horracing.com/product_info.php?products_id=358
Would it work?
The boat
<meta charset="utf-8" />Here it is
http://s1123.photobucket.com/albums/...t=RK000018.jpg
And I was also looking at this prop:
http://www.horracing.com/product_inf...products_id=85
<meta charset="utf-8" />I would like to go like this fasthttp://www.youtube.com/watch?v=6HrgSmfcTaQor possibly faster. I am open to suggestions about adding things like ballast, a keel or an outrigger if you think that they are needed.
Thanks, ZAne
Would it work?
The boat
Thanks, ZAne
