impulse 26 brushless
hey guys i want to put a brushless system in my proboat impulse 26 im thinking of putting a velineon 3500 with the esc i can buy that combo for about $150.00 my question is will it work
NC
RE: impulse 26 brushless
The traxxas motors are overpriced. You can save a lot of money and get better equipment. I'm not a fan of the traxxas brand motors, I have taken them apart and for there price I was unsatisfied to say the least.
* That boat may not handle the increased speed all that well, I'm not sure. It was designed for brushed power entry level boat so the performance increase may cause some other issues. I wouldn't get crazy with it. If you go with the Traxxas 3500 only run it on 2s NOT 3s, stuff will get smokey for sure on 3s rpm's to high.
At 26" I would go with a 4s setup, but a 3s setup "could" work. There's more options with a 4s setup then there is with a 3s setup.
Esc for either (amazing esc's!) http://www.hobbypartz.com/se12b.html
3s:
http://www.hobbypartz.com/07e-c-sl-8t-3660-blue.html(35-38mm prop range)
3s or 4s
http://www.hobbyking.com/hobbyking/s..._Inrunner.html (38-40mm props range)
4s
http://www.hobbyking.com/hobbyking/s..._Inrunner.html(40-42mm prop range)
* There are MANYmotor choices that can and willwork, Ijust wouldn't dump to much moneyinthat boat. It's an entry level boat and you can pump the speed up a little, but it's just not made for high speed.
would this be a good setup for my boat and if so what prop would the stock one be ok
http://www.hobbyking.com/hobbyking/s...Lipo_Pack.html
http://www.hobbyking.com/hobbyking/s..._for_Boat.html
http://www.hobbyking.com/hobbyking/s..._Boat_ESC.html
NC
No that wouldn't be a good setup for this hull. It is a good setup in general, but for a much bigger hull example I run that size motor (different kv and larger esc) in a 33" mono... For this hull, way WAY to much power. Would make the hull very very unstable. JMHO....
ORIGINAL: miamibanshee
thank for all ur help and patience with my i was just trying to see my options with what you have told me i think im going to go with the esc that you told me and the last motor, is that the best one of the 3 and also what battery should i get
