Go Back  RCU Forums > RC Boats > Speed - Electric
Reload this Page >
miss vegas electric conversion
Speed - Electric For all your electric boating needs.
Old 02-25-2012, 08:16 PM
fast water
Default miss vegas electric conversion
looking to repower my vegas with brushless. i have a 500 heli brushless and a 600 also with speed controls. will either of these work and if so is 6 s too much?
Old 02-28-2012, 04:09 PM
madmorgan
Default RE: miss vegas electric conversion
depends on kv of the motors the 500 should suffice  your shooting for around 30000 rpm unloaded im going to be trying out leopard 1550kv on 5s2p with a 200 a  esc  best prop i have found on the vegas's are the y535 but i think i will try a bit bigger say a 440 and see how it goes. google miss vegas deuce make it faster theres a ton of good advice.
Old 02-29-2012, 10:04 AM
fast water
the motor i have is a 1695 kv wich unloaded on 6s is 37629 rpms unloaded. droppin to 5 s is31357. think 5 s is way to go or 1 2s1p and one 3s 1p and figure out the balance the boat afterward!
Old 02-29-2012, 10:46 AM
madphil
You will be ok with 6s on that motor ,
i race with a 1680kv on 6s with 42mm 2 blade prop or a 40mm 3 blade ,
also you may get a better balance using 2x 3s packs one on each side
Old 02-29-2012, 11:13 AM
Goldenduff
Do you not to run identicle packs if connecting together?
Old 02-29-2012, 03:51 PM
fast water
u can run odd size packs in series as long as they same mah abd c rating. prob just as well that they be of the same brand just to avoid other probs.
Old 02-29-2012, 11:44 PM
Goldenduff
Sorry don't understand, they can be odd packs as long as capacity and C are the same, so that just leaves its okay to run different voltages? Thanks
Old 03-01-2012, 04:17 AM
madmorgan
no you can run say 2s1p 30c 5000 mah in series with a 3s1p 30c 5000 mah to achieve 5s 30c 5000 mah   you cant run say 2s1p 20c 4000 mah with a 3s1p 25c 5000 mah
Old 03-01-2012, 04:19 AM
madmorgan
or shouldt lol
