If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Results 1 to 11 of 11
  1. #1
    Looking for the right prop .... here's what I have
    Delta Force 29
    PB 1500KV
    CC Hyrda Ice 240
    (2) 3S Nano-tech 65C 5000mah lipo's
    ... currently running an x440
    any suggestions as to a better prop?
  2. #2
    Join Date
    Dec 2010
    meanwhile, ON, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Looking for the right prop .... here's what I have
    I don't really know how to suggest a "better prop," is the current one causing handling problems or do you just want to go faster?
    You can get larger diameter props to up your speed a little, or does the motor already run hot?
    you don't want to fry any components, the props are a lot less expensive then the motor or the speed controller.
    Clock.
    If it isn\'\'t capable of turning itself into shrapnel, it needs more power!
  3. #3
    Nah
    Temps are bueno
    Just wanna go faster
  4. #4
    Join Date
    May 2007
    InnisfilOntario, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    If you're motor is running cool, I see no reason not to go with a 442, or 445, if you want to venture with 640 go for it, you won't know until you try.
    There is no right prop, go by the heat of you're electronics, that what everyone does.
    I tried a 442, 445 on mine it still cool and I mean under 90F, I'm getting a 642 ready to give it a try.
    Here are some cheap props you can try, when you find the right one you can upgrade to metal prop.
    http://www.offshoreelectrics.com/pro...t=Carbon+Props
  5. #5
    Join Date
    Jan 2011
    Clive, IA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    GrimRacer prop-42 x55-Just kidding- i like Octura 637 on 4S with a Bar-Cut.
  6. #6
    Join Date
    Aug 2007
    Brisbane, AUSTRALIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    A good prop for that rev range in that hull is an X440/3 blade more stable in the turns too.
  7. #7
    ok , I got in a 50mm and a 52mm plastic guapners. I like how sharp they are !!!! I though I had a sharpened x440 but its dull as hell compared to these new ones !!! I wish I could run, but had a hose come off while running the other night (and yes it was the middle of the night) filled the heck out of the hull. my CC 240 was wasted. I hope the tech is in a nice mood when it gets to them....
    question, I often run 2, 3 and 4 S along with 6S. How would a bigger prop like what i mentioned do with the weaker power set ups?
  8. #8
    Join Date
    Aug 2007
    Brisbane, AUSTRALIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I can't comment on a 3s, or 2s , but on 4s with that motor we run the M645, or X645 in our Restricted Class with those motors. Some run an X447. And that's with the original 45A ESC's. Thin it, sharpen it, balance it.
    You really only need a 120A ESC at the most with that motor.
  9. #9
    Join Date
    Jan 2008
    Frederick, CO
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    if you run 6s try a x640
    first to own the Mini Slash!
    Amsoil Dealer.. 6XL Revo, Baja 5B, Losi8T, PS295, UL-1, AQ MC, OM29, DF33
  10. #10
    Join Date
    Jan 2009
    , CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    i have a x645 i removed the tounge (copied an m series i had) back cut it about an 1/8th inch and cuped the tips up a bit. Seems like a good runner on my geico. Not with a stock esc or anything though. 80-90 amps on my set up.
  11. #11
    Hey guys.
    I think I figured out my problem.
    I don't know if it was on the timmimg setting or what. But I'm glad my cc 240 got ruined. While I waited on myth em to replace it. I picked up a hobbywing for $80. And the boat flippingxhaulls!!! I finally know what you guys arextalkingxabout when you say 6 s might be too much!!
    Don't know who told me about it. But wow!!!
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
