If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Results 1 to 7 of 7
  1. #1
    dauntlessfan's Avatar
    Join Date
    Oct 2006
    DFW TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    41" Cat Hull Looking for Help with Beginner Setup
    Went by my LHS today and saw this baby for $25 so I grabbed it. I figure at the very least it's cool to display in the workshop!
    My experience is mostly in scale boats so I'm really not sure what I got? Or if it's elecric or nitro? Or if it's something I can get up and running at the lake without taking out a second mortgage?
    Hull is about 41" long, thick fiberglass and very solid. No prop was included, but I'm pretty sure the output shaft is 3/16".
    Any friendly advice on a beginners setup for this boat (motor, speed control, prop, batteries, motor-to-shaft coupler, etc.).
    I'd really appreciate some opinions.
    Thanks everybody!
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	1763364   Click image for larger version.
ID:	1763365   Click image for larger version.
  2. #2
    Join Date
    Dec 2010
    meanwhile, ON, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: 41
    Definitely an internal combustion engine, the motor mount with the rubber absorbs the vibrations.
    Talk to the nitro guys they would be able to help.
    Or you could switch it to electric. you just need to remove the motor mount and put in an appropriate one,
    Which would you prefer?
    Clock.
    If it isn\'\'t capable of turning itself into shrapnel, it needs more power!
  3. #3
    Dan S's Avatar
    Join Date
    Aug 2006
    Oromocto, NB, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: 41
    Looks like the 42" Aeromarine Sprint Cat .80/.90 with the turbine cowl.
    Nitro engine mount for a .80 to .90 nitro engine.
    if rails are 5 inches apart you can convert it to a 26cc gas engine and if flex shaft is 3/16 I would switch to 1/4 inch for gas.
    but 3/16 should be fine for nitro or electric.
    To convert to electric is absolutely possible.
    what are your goals, speed wise?
    running time?
    and most importantly, what are you willing to spend?
    Dan.
    F-41 Stryker Cat 260 Full Mod - Whiplash GV NFS 260 - FireFighter 18 - Miss Vegas CVRM 18
    Futaba FASST
  4. #4
    Join Date
    Oct 2006
    DFW TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: 41
    Thanks everyone for the great info, much appreciated.
    I'd prefer to convert this one to electric, just not sure what motor/speed control/prop combo would work.
    My goal would be a budget boat that gets along at a decent clip, but I don't need to break any speed records, rather I'd prefer longer run times, less maintenance, lower cost. Maybe something I could upgrade later on down the road.
    Definately something brushless. I've been in the RC hobby since the 80s, and still have yet to try brushless . I think it's time to step into the new milennium, technology-wise .
  5. #5
    Join Date
    Jan 2008
    Frederick, CO
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: 41
    this ones going to be fun!
    big Leopard on 10s will get it going well [:-]
    first to own the Mini Slash!
    Amsoil Dealer.. 6XL Revo, Baja 5B, Losi8T, PS295, UL-1, AQ MC, OM29, DF33
  6. #6
    Old Sloppy's Avatar
    Join Date
    Nov 2006
    Buford, GA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: 41
    ORIGINAL: dauntlessfan
    if it's something I can get up and running without taking out a second mortgage?
    Thanks everybody!
    Step one is to take out a second mortage........(He, He, He)
    Harry
    Trex CF 600e,
    Futaba 7CH 2.4 ghz,
    Air Thunder 6s 5,000 mah
  7. #7
    Join Date
    Nov 2006
    Texas TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: 41
    Harry has a point, a big 10S cat can be expensive. You need to know what you are getting into before you start. Harry and I both have run plenty of big 10S boats and we have a pretty good idea what works and what does not. I'm not trying to discourage you, we'll give you plenty of good advice. But plan on well over $1000 for the build. With FE boats, you can have cheap, fast or reliable, choose any two.
    BTW, don't listen to advice from those who have not actually built and run 10S boats. It is always so much easier to plan someone else's build when it isn't your money being spent.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
