If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Page 4 of 5 FirstFirst ... 2345 LastLast
Results 76 to 100 of 109
  1. #76
    Join Date
    Jan 2004
    Blaine, MN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Aquacraft Revolt 30
    anyone else buring up the motor with the stock set up on this boat? I am on #2
    my amp meter registered a 52 amp max draw do the boat is not over proped or setup with the prop too low in the water.
  2. #77
    Join Date
    Jan 2004
    Blaine, MN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: diy-pro
    next time post a link you goob. I tried finding yours and i found a cheaper one for 18.58!!! [img][/img]
    Β* http://www.ebay.com/sch/i.html?_nkw=...at=0&_from=R40
    120968806965 Item number on eaby
  3. #78
    Join Date
    Mar 2011
    Ben Lomond, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: hobby_man
    Did you open up the water inlet on the rudder blade? Maybe you are not getting enough cooling?
  4. #79
    Join Date
    Jan 2004
    Blaine, MN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    you mean modify the stock rudder? NO I have not touched the boat it's stock. I got it for my grandson as a no mees with always runs boat.
    speed cost money and time and I do not want to ruin his fun by getting him into my FE boating world
  5. #80
    Join Date
    Mar 2011
    Ben Lomond, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    There lies your problem sir. Check the Aquacraft website for an addenum about 2 issues with this boat. 1. water inlet 2. removal of glue from shipping tape on the hatch/canopy
    The water inlet on the rudder needs to be opened up and elongated to allow more water flow through the cooling system. I used my dremel and a round jewelers file to open up and extend the water inlet cooling hole on the rudder (towards the leading edge of the rudder)
    I also found ALOT of aluminum shavings inside the cooling inlet hole on the rudder (from when it was drilled out at the factory in China) which would have surely clogged or blocked the entire cooling system
    Good luck sir! And keep us posted.
  6. #81
    Join Date
    Jan 2004
    Blaine, MN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: Wavekatcher
    There lies your problem sir.Β* Check the Aquacraft website for an addenumΒ* aboutΒ* 2 issues with this boat. 1. water inletΒ*Β* 2. removal of glue from shipping tape on the hatch/canopy
    The water inlet on the rudder needs to be opened upΒ* and elongated to allow more water flow through the cooling system.Β* I used my dremel and a round jewelers file to open up and extend the water inlet cooling hole on the rudder (towards the leading edge of the rudder)
    I also found AΒ*LOT of aluminum shavings inside the cooling inlet hole on the rudder (from when it was drilled out at the factory in China) which would have surely clogged or blocked the entire cooling system
    Good luck sir! And keep us posted.[img][/img]
    WOW, I have to wonder why Aquacraft did not fix the issue the last time they replaced the motor for me, its in the shop now for its 2nd motor.
  7. #82
    Join Date
    Jan 2004
    Blaine, MN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I just read the tech note at the aquacraft web site. I registered the boat, so they know I own it, this memo should have been sent out to all registered owners ***?
    I felt bad about the motor frying, I just got over that!
    A _ick head move by some 24 year old marketing idiot at Aquacraft!
    This pisses me off, I called the tech's and told them over and over that this boat is getting too hot! they blew me off!
  8. #83
    Join Date
    Mar 2011
    Ben Lomond, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Maybe call them and tell them you just found out about the issue. They should have included a hard copy of the issues needing attention with the manual.
    The chimps doing the fix probably have no idea about the water inlet, nor will they have the tools (or knowledge) to fix it.
    The only way I knew about it is by wasting my time on these forums
  9. #84
    Join Date
    Mar 2011
    Ben Lomond, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: hobby_man
    My 1st revolt had serious alignment issues with the motor and stuffing tube/flex shaft alignment. I called Hobbico and the tech guy said "its fine to run it that way as long as the shaft isn't rubbing the brass tube" BS, I sent it back to Tower and they sent a replacement.
    The replacement still isn't aligned perfect. Aquacraft has drunk chimps building these boats.
  10. #85
    Join Date
    Jan 2004
    Blaine, MN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    well I am sending this Revolt boat back for repairs, the 3rd time
    first time was a motor/speed control replaced
    second time same
    third time same, I think
    I have had this boat 10 weeks, I got it when it first came out. I called the tech's complaining about how hot the boat got and was told not to worry about it, its fine
    Then Aquacraft comes out with a tech update on their web site to modify the rudder intake hole which I was told by someone on this site.
    I registered the boat they never contacted me AND while the boat was in for repairs the 2nd time Aquacraft did not update the rudder that they are telling us to do.
    Now the boat is going back the 3rd time for what I think is the motor burn out. The boat quit and then the motor was herkey jerky for a turn and then quit turning. The speed control will not arm.
  11. #86
    Join Date
    Jan 2008
    Frederick, CO
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    very strange................
    I just got mine from Tower, and everything is perfect on my Revolt30
    first to own the Mini Slash!
    Amsoil Dealer.. 6XL Revo, Baja 5B, Losi8T, PS295, UL-1, AQ MC, OM29, DF33
  12. #87
    Join Date
    Jan 2004
    Blaine, MN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: srt10
    did it come with the slot in the rudder opened up? If not see the tech note on the aquacraft web site.
    I am running mine with a pair of 2s 10,000 mah lipos,
    try running the boat for 7 minutes straight, you can fry an egg on the motor and the solder joints on the bullets let loose and the wires melt the foam on the hatch.
  13. #88
    Join Date
    Jan 2008
    Frederick, CO
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    rudder looks nice and clean I'll try and get a picture for you today..
    looks on modded
    what prop are you running?
    also what is your CG at?
  14. #89
    Join Date
    Jan 2004
    Blaine, MN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    My boat is stock, so it would be the 42x55 grimm
    I don' know the CG off the top of my head, what are you running for a CG?
  15. #90
    stuball56's Avatar
    Join Date
    Apr 2007
    Grand Rapids, MI
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Well, yes. Running for 7 minutes straight will straight up ruin most setups in a FE  boat setup to run on the edge. I f running 7 straight minutes is your goal, then you need to prop down, alot.
    PPPHEEEEEEEWWWW!!! Nitro Stinks!!!
    Electrics ARE the future, and the future is NOW
  16. #91
    Join Date
    Jan 2008
    Frederick, CO
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: stuball56
    Well, yes. Running for 7 minutes straight will straight up ruin most setups in a FEΒ* boat setup to run on the edge. I f running 7 straight minutes is your goal, then you need to prop down, alot.
    stock this boat is not on the edge with a 42x55 prop
    this boat should be able to run 7 minutes without any issues, so something else is up.
  17. #92
    Join Date
    Jan 2004
    Blaine, MN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: stuball56
    it's a stock out of the box boat! So it not running on the edge!
  18. #93
    stuball56's Avatar
    Join Date
    Apr 2007
    Grand Rapids, MI
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Well, when mine was "stock" it got quite hot after 4 1/2 minutes straight out running. So I changed the esc, wires, and bullets. Now I run a GR 42-55 with a Aquastar 120 and 5.5 battery connectors and 6mm on the motor. Still gets mighty warm after 3 or 4 minutes of hot laps. I don't question that you have a problem, just commenting is all.
  19. #94
    Join Date
    Jan 2004
    Blaine, MN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: stuball56
    Well, when mine was ''stock'' it got quite hot after 4 1/2 minutes straight out running. So I changed the esc, wires, and bullets. Now I run a GR 42-55 with a Aquastar 120 and 5.5 battery connectors and 6mm on the motor. Still gets mighty warm after 3 or 4 minutes of hot laps. I don't question that you have a problem, just commenting is all.
    I Understand, sorry just a little miffed with this boat, I spent last summer with a Traxxas Spartan. It took me some time to get all the bugs out of it.
    I figured I would leave this unit stock and it would run,,,NOT
    I had not opened up the hole on the side of the rudder until I got it back from the 2nd repair, which they resoldered the bullets, I belive the motor was bad so when I ran the boat for 3 minutes the 3rd time it died. It wasnt the bullets.
    I did note more water coming out the exit tube and the motor inside of the boat was cooler when I first opened the hatch. Cooler than in the past. In the past blue smoke would come out when I opened the hatch, blue smoke = burning winding
    If Aquacraft would have replaced the motor the 2nd time and I did the rudder mod I believe the boat would have run fine.
  20. #95
    stuball56's Avatar
    Join Date
    Apr 2007
    Grand Rapids, MI
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Ya, I hear ya though. When I got my first FE boat, a Motley Crew, it was in such need of "fixup" that I almost quit the hobby before I got started. Now my MC is quite heavily "modded" and I love love love it.
  21. #96
    Join Date
    Feb 2008
    VancouverBC, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Mine had a faulty rudder to start with. Water cooling hole was drilled but not all the way through. In other words, no water was going thru to cool the motor or ESC. Luckily I caught it after the first run, it was smoking hot after a 3 minute run.. Emailed Aquacraft about it and they blew me off. I sent it back to my LHS to deal with them directly. Definitely disappointed about the customer service; I have had way better experiences with Horizon and my Proboat models.
    But honey, I had to buy all those RC cars today because the exchange rate was good.
  22. #97
    Join Date
    Jan 2008
    Frederick, CO
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Never had an issues with AQ customer service
    IMO, the best around
  23. #98
    Join Date
    Jul 2012
    Ironton, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hey, I have a question about my lipos for my Revolt 30. I have 2 of the 2 of the GrimRacer 7.4V, 5000 mAh batteries. Attached is a picture of my charger while charging and a picture of my meter immediately after charging. How is it possible for each cell to be over 3.7V?? Why does my charger show 8.16V while charging?? I removed the battereies from the charger as soon as they were complete. My meter showed both batteries charged up to 99%.
    Please help me understand, thanks!!
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	1796090   Click image for larger version.
  24. #99
    Join Date
    Jan 2004
    Blaine, MN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: Brad Mc
    Hey, I have a question about my lipos for my Revolt 30.Β* I have 2 of the 2 of the GrimRacer 7.4V, 5000 mAh batteries.Β* Attached is a picture of my charger while charging and a picture of my meter immediately after charging.Β* How is it possible for each cell to be over 3.7V??Β* Why does my charger show 8.16V while charging??Β* I removed the battereies from the charger as soon as they were complete.Β* My meter showed both batteries charged up to 99%.
    each cell of any lipo battery shows a voltage of 4.2 when charged
    each cell should be at 4.2 so the cells are balanced/charged, if you get one cell at 4.2/4.19 or so and the other cell only gets to 4.0/4.01 the cells are off
    you should follow the 80% rule, do not discharge any more than 80% of the batteries capacity
    5000mah x .8 = 4000 you should see about 4000 mah being charged back into the battery
    at the 80% discharge your cells will be about 3.6 volts each
    if you over discharge the battery, say you take 5200 mah out of the battery your cells could drop below 3.0 volts and then the charger will give you a low voltage error and it will not charge them capacity
  25. #100
    Join Date
    Jul 2012
    Ironton, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Ok, thanks Hobby Man!
    I'm in good shape. Yes, I always stick to the 80% rule.
    Thanks again.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
