Thunder Tiger Outlaw Jr. Brushless
My Feedback: (20)
RE: Thunder Tiger Outlaw Jr. Brushless
ORIGINAL: diy-pro
Srt10 how do you calculate its 4 x more power? Is there a chart to match a boat Hull and weight to certain size of brushless motor?
the Leopard motor is 1.5 times bigger in dia.
and almost 2 times longer
a bigger motor with the same kv = more torque and more HP
that little 28mm motor is rated to 640watts max and that would be for a very small car, like 16th or 12th scale..
this boat of yours is more of a .21 size nitro
so you need HP and torque.... no replacement for displacement
the bigger Leopard is rated at 2000watts, but I've seen them run higher without issues
I have the 4092 2080kv in my DF33 and it flat out hauls!!
Run it see how hot it gets. if you havnt ordered the esc yet get atleast a 60a it will give you more headroom. Which esc and motor?
CA
My motor that i have is just a motor from a 1/10 short course truck..no real markings for me to know what brand just some random china motor.
Diy-pro, i did buy the esc unfortunately...i should have looked around on forums first to see what i should use[:@]
#31
CA
I did run my motor for a little while with the provided 35 amp fan cooled car esc. the motor stayed warm but the esc felt like it was gettiun way to hot around 65c i think
#32
you may be fine if you dont put too large of a prop on it. You have a cooling jacket for the motor?
Found this >>> http://www.himodel.com/electric/2080...F540-3650.htmlThis ones rated at 38 amps Youll probably be fine just check the temps
#34
CA
My thunder tiger outlaw and radio[img]DSC_2557[/img] The main layout of electronics except for the esc that goes in the middle of both batteries[img]DSC_2552[/img]the motor im using..3650 2080kv, brand unknown[img]DSC_2554[/img]Front view looking towards stern[img]DSC_2555[/img]
#37
Lol i dont see anything but thats good if it covers the whole thing :-/ BTW dont take anything i say seriously ive never owned a brushless system. But once again youll be fine just check the temps
#41
How are you guys mounting these big motors? Also how do mount my packs outside the radio box? Just stick on Velcro? I'm running the desperado by the way.
#42
CA
Hi there, to be honest I haven't done anything with this project but for a mount make your own if you can. The desperado if I'm right has a flex cable therefore you have better options for motors. I found with the outlaw that the straight shaft proved to be a problem in mounting. What are the deminsions from the boat hull bottom to the canopy?
#44
CA
I guess you could you would have to figure out a way to raise the mount up in order to mount a motor to it. Thats simple though, a wood block would do the job im sure. just make sure its glued down good[8D]
#46
CA
Your gunna be running way to hot with that motor. Go back to the first page if you haven't already, there's a discussion about putting a 28mm I runner in there....it's not the same
#48
that was the motor i wanted to put in With those mounts from hobby king, do you just glue them? Also how do i mount my batteries outside the box?
#49
Two guys at our club had bought one of these each some time ago & because of the angle of the shaft they ran too wet no matter where they put the batteries.
So out came all the innards & drive shaft.
In went a 3674 2200kv turnigy motor and a 120A ESC with a strut & flex drive.
With a 437/3 prop they are damn fast. With a 440/3 they are ballistic. with cool electrics & a decent run time on a single 5000mah 4s pack.
srt10 is spot on with the motor choice.
For those still wanting to run a 28mm motor on 3s in this boat. I can recommend this motor with a 440/3 or a 442 two blade.
[link]http://www.horracing.com/product_info.php?products_id=593[/link]
I've had it in a 25" bling rocket & it is a wee little beastie of a motor. I even ran it on 4s with a 437/3 prop. No problems but you will need a 120A ESC at least. I popped an 80A ESC with it. It easily puts out the 1000w that it states.
Cheers.
Paul.
Cheers.
Paul.
#50
Hi HiBob.
We just usually stick velcro on the batteries & in the hull.
Where in Australia are you. Not in Brizzy by any chance are you.
