If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Results 1 to 7 of 7
  1. #1
    nitrosportsandrunner's Avatar
    Join Date
    Aug 2007
    skowhegan, ME
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    SV27 wont stay in the water!
    I took my SV27 to the lake today (1st time)
    It was fairly calm. but I couldnt get the throttle above 3/4 cause she was jump out of the water. It landed upside down one time. Lucky some boys were eager to go get it for me. No damage, but whats the point of a super powerful boat when I cant use more than 75% of the power?
    I figure that my issue may be largely due to the lipo batteries. Im sure the boat was setup for the weight of nimh packs and that my lipos are lighter and thus allowing the front to lift too much. even at 1/2 speed the front lifts and then slaps down (repettitive motion) very bad.
    Now, Id assume that the tabs and parts on back with adjustments may cure the issue. but I am trying to sell the boat and dont really wanna mess with that stuff(and risk making it worse)
    Can I add some weight ahead of the motor to counter-act the lighter lipo packs?
    It also likes to "bog" when turning (rear staying to far down in the water)
    I have never felt so "out of control" while driving an RC as with the SV27. This thing likes to be right on the edge 100% of the time.
    any tips? is adding weight a good/bad idea? anyone wanna try and explain what the bits on the back do?
    1/6 hummer crawler, HG P402, FJ40, Evader Bx, Kyosho Sand Master, Stampede, ECX Circuit
  2. #2
    Dan S's Avatar
    Join Date
    Aug 2006
    Oromocto, NB, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: SV27 wont stay in the water!
    how much positive do you have on the strut (prop pointing up) ?
    Dan.
    F-41 Stryker Cat 260 Full Mod - Whiplash GV NFS 260 - FireFighter 18 - Miss Vegas CVRM 18
    Futaba FASST
  3. #3
    Old Sloppy's Avatar
    Join Date
    Nov 2006
    Buford, GA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: nitrosportsandrunner
    adding weight is a bad idea.
    Harry
    Trex CF 600e,
    Futaba 7CH 2.4 ghz,
    Air Thunder 6s 5,000 mah
  4. #4
    siberianhusky's Avatar
    Join Date
    Nov 2009
    Peterborough, ON, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    They handle pretty good if you actually take the time to learn how to set up a boat. Mine loves full throttle.
    Boats aren't for everybody as you actually have to learn something and be ready to turn some wrenches and screwdrivers.
    Damn huskies ate it!
  5. #5
    Join Date
    Sep 2004
    KitchenerOntario, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Is it the "R" version or the older version? Older version has the batteries mounted in the rear, R has them more centerally mounted....Mines the older version and I place my Lipos in a V formation in front of the motor..that with some proper strut and tab adjustments will sort things out, but only so much....I've had 3 SV's over the years, still fun boats, but they earned their nickname "superflip" for a reason.
  6. #6
    Join Date
    Aug 2010
    Charlotte, NC
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I disagree. Weight can be your friend
    - Here's some tips, if your trays are in the boat (old sv) remove them.
    - Move your lipos further forward, I ran mine at the leading edge of the rails towards the motor mount
    - A few oz of weight or a small gps unit just forward of the motor helps a lot
    - Make sure the strut is neutral
    - Tucking the rudder under the boat and round off the lower leading edge of the boat helps a lot
    - I ran may trim tabs slightly up, The kintec trim tabs with the locking bolt are awesome the stock ones can bend and flex under running conditions.
    Here's my old SV. She ran awesome, sadly she crashed pretty hard when I tried to hit 60 with her. $5 bet and I lost
    UL1 powered: http://www.youtube.com/watch?v=_t1ksDActBo
    7Xl powered: http://www.youtube.com/watch?v=6JSwz6hiRwc You can see where my lipos are in the still photos at the end. The Gps went in front of the motor, but was removed
    The last clip is my 60mph attempt that didn't end well: http://www.youtube.com/watch?v=I7if0FMzIL4 Starts at 1:44
    ORIGINAL: Old Sloppy
    Harry
    Fast Electric Addict! I like to go fast!
  7. #7
    Old Sloppy's Avatar
    Join Date
    Nov 2006
    Buford, GA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I did not say Weight is not your friend,
    I said adding weight is a bad idea.
    A better idea is to move the weight to a new spot preferable to "centralize the mass".
    Trex CF 600e,
    Futaba 7CH 2.4 ghz,
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
