Speed - Electric For all your electric boating needs.
Shark 650EP Boat
Reply
Old 01-06-2013, 04:04 PM
almaidah
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Shark 650EP Boat
Yes they are fun if you get a chance check out my other videos . I'm not looking for any more speed with that boat but I would like a metal prop the same as the stock just so I know that it won't break as easy as the plastic prop
almaidah is offline
Old 01-06-2013, 04:20 PM
*delete M i k e u p delete*
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Specs read kv at 5400 x 7.4 = 39960 x .80 = 31960 rpm== .80 is efficiency is a round figure. Video shows it handles the rough stuff real well. Take care.** itook the kv off a site and thought it was high. I checked another site and saw 4500kv which was more like it. 4500 x 7.4 =33300 x .80 26640 rpm. Nothing wrong with that.
*delete M i k e u p delete* is offline
Old 01-09-2013, 12:24 PM
grimgard
grimgard's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Why is your Shark jumping around in the water so much? Mine is super stable and looks faster than yours in the video. I know it's hard to tell speed from a video. Maybe it's because I am using a 4mm flex shaft and the prop is deeper in the water? anyways I doubt I could get mine to flip it's that stable in the water. I am running a 3s Lipo on a 2900kv motor.
grimgard is offline
Old 01-13-2013, 07:17 PM
almaidah
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
In person the shark is running smoothly across the water just at the end it flipped
almaidah is offline
Old 04-10-2013, 08:22 PM
sldtung
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Dear all master,
May I know if the drive shaft broken where can find the replace parts ? I tried to find Nitro RCX  but it show long time out of stock.
Would you please help me where can find this boat replace parts ? Please advise !
sldtung is offline
Old 04-11-2013, 04:03 AM
  #31
almaidah
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Offshore electrics should have some shaft for you
almaidah is offline
Old 04-11-2013, 09:41 AM
  #32
grimgard
grimgard's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: sldtung
Dear all master,
I got mine on Ebay http://www.ebay.com/itm/4mm-X-14-cab...&_qi=RTM759771 and then I cut the cable to length.
grimgard is offline
Old 08-27-2017, 11:09 AM
  #33
P-TownOrginal623
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Help with esc for shark
i have a shark as well but I don't have the Manuel or esc programming pamphlet is there anyway you could snap a pic or it and email it to me?
P-TownOrginal623 is offline
Old 08-27-2017, 11:12 AM
  #34
P-TownOrginal623
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Can anyone help me!?!?
I also have the shark 650ep but I don't have the paperwork that tells you how to program the 70a esc, I would like to know how to program it because I don't have reverse or anything like that...please help and thank you in advance
Old 09-09-2017, 11:18 PM
  #35
cablecar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Try using 2 blade p1.4 36 CNC Prop. or 37, if you using 3 blade 36 is fine, then it must handle 36 / 37 2 blade prop.
Using 2 blade raise out of water faster (Start Up) than using 3 blade. Motor and ESC also less heat.
cablecar is offline
Old 09-14-2017, 04:46 AM
  #36
cablecar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Do you thunk the 435 octura prop will be ok on mine?
I suggest using Tenshock / TP CNC prop 36/37 2 blade would be good for Mono
cablecar is offline
