If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Results 1 to 13 of 13
  1. #1
    Join Date
    Apr 2013
    NL, NL, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ProBoat Miss Geico 24 RTR - 1st Run
    Hi everyone. Things looks like a great forum!
    I've a new comer to the sport of RC boating and just picked up the ProBoat Miss Geico 24 RTR.
    So far my experience has been fairly disappointing, perhaps the experts here could shed some light on my issues/questions below?
    1. Using the charger provided (Dynamite 2A NiMH AC Charger: (DYN4113)), the battery provided (Speedpack 2400mAh Ni-MH 6-Cell Flat with EC3 Conn
    by Dynamite (DYN1060EC)) only lasts 40 seconds before the boat really slows down, starts to turn in one direction by itself and eventually stops responding to throttle (steering is responsive when throttle stops).
    NOTE: The same is happening with two DuraTrax 5000mAH packs charged with the same charger. Each time Icharge Iconnect it, I hit the start button, and an hour later (sometimes less) the charges reads GREEN for charged. So I try and use the pack.... with the results above.
    2. What is the typical range on this boat? I am loosing control (no response for a few seconds - the boat stops responding to Throttle and Steering and seems dead in the water - for 1-2 seconds when only about 100' away. I range check Tx and Rx before running. Tx batts are fully changed AA.
    Any advice / direction on sorting these issues would be great - as it is the boat is not fun and hardly usable compared to what was advertised.
    Appreciate your comments and insight.
    Thank you.
  2. #2
    Join Date
    Oct 2009
    Cheverie, NS, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: ProBoat Miss Geico 24 RTR - 1st Run
    This all sounds to me like a bad charger.  If it is a 2A charger it should take at least 2 hours to charge up the 5000mAh packs (maybe 3 if they are completely dead)
    I do not have a miss geico, but assume it is running a BEC (no separate battery for the Rx) - if so, when the main pack goes dead (or close) the BEC can not supply enough voltage to the Rx, and it will cut out like that.
    Starling Design Company
    http://www.starlingdesign.ca
    web & graphic design
  3. #3
    Join Date
    May 2013
    middx, UNITED KINGDOM
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hi Propeffect,
    I get the same experience with my new Miss Geico.
    Works fine for around a minute and then stops repsonding.
    Rudder turns but no throttle.
    If you find any answers please share.
    Mark
  4. #4
    Join Date
    Sep 2004
    Celina, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Put lipo batteries in it.
  5. #5
    Join Date
    Jul 2010
    Morrisonville , NY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Did you by any chance get this figured out? i just got this boat and it does that same thing out of the box. Horizon hobby has been no help at all... Did i just buy a paperweight? Help please if you got your figured out! Thanks
    ORIGINAL: propeffect
    Thank you.
  6. #6
    Join Date
    May 2013
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hi
    I bought another battery a 5100nimh battery. I am not ready for Lipos as yet.
    The Horizen web site said that the battey and charger that comes with the unit is a little iffy.
    They advise that the first charge should leave the battery a little warm, which it did not when I tried to charge mine.
    So they advise to charge the battery and then then check the temperature straight away. If the battery is not a little warm then, charge the battery again.
    I did this and the second or third time, bingo!
    The battery that comes with the boat is really not much use, but you should get at least ten minutes.
    When I bought the new one, it was amazing the difference. (still had to charge twice the first time)
    The boat goes twice as quick and it lasts twice as long.
    Hope this helps.
    I am a newcomer so please bear with me :-)
    Mark
  7. #7
    Join Date
    Jul 2010
    Morrisonville , NY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    what battery was it that you bought? Link? does the original charger charge the new battery? thanks
    ORIGINAL: marky_dude
    Hi
    Hope this helps.
    Mark
  8. #8
    Join Date
    Jul 2010
    Aberdeen, UNITED KINGDOM
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Sometimes "smart" chargers are too clever. Perhaps the peak detection is too sensitive and detecting a false peak and stops charging. Either change the peak detection or charge on a dumb charger until warm. All the best
    Happy Landings
  9. #9
    Join Date
    Jul 2010
    Morrisonville , NY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    when i charge the battery, it says its charged after 15 min. the battery is hot? faulty battery or charger maybe?
  10. #10
    Join Date
    Jul 2010
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hot might be damaged. Can you take a volt reading? If getting in to electric you should really invest in a volt meter and power meter....
    Happy Landings
  11. #11
    Join Date
    Jul 2010
    Morrisonville , NY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    i can borrow a voltage meter and test it. assuming its fully charged what should it read? thanks for the help, this is all really new to me and i would just like to be able to figure out my problem and use my boat!
  12. #12
    Join Date
    Aug 2007
    Brisbane, AUSTRALIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    The old metal cells should have a "Formative Charge" as their first charge. That means that they should be discharged to 0.9V /cell at 0.5 Amp load.. That's 5.4V for a 6 cell pack.
    Then charged up at 1/10th C. That's 0.24A for the 2400mah pack, & 0.51A for the 5100mah pack. This avoids the 'False Peaking' & gets the chemistry working properly & believe it or not, balances the cells.
    The next few cycles can be charged at 1C as per normal. 2.4A for the 2400mah pack & 5.1A for the 5100mah pack.
    But don't over discharge them. As soon as the boat starts to slow bring it in. Let them cool & recharge them.
    After that, run them as hard as you like.
    The 'Formative Charge ' sequence should be done every 10 or so cycles. This will ensure well balanced long lasting packs.
    Also. Store them fully charged. Not totally flat. Just top them up before use.
    If they are not used for a long time. 3 months or more. Do the formative charge sequence again before use.
    Hope that helps a bit if you are going to use the old round cells.
    Aaaaah the memories of racing with these cells.
    Cheers.
    Paul.
  13. #13
    Join Date
    May 2013
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Thanks Paul, good post! The charger that comes with these boats, dont have any subtle settings. Just on or off.
    But after the formative charges, they batteries really start to show the differences.
    Thanks again.
    M
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
