45 inch xcat
45 inch xcat
hi guy's working on a 45 inch xcat with two proboat outboards with counter props. should be a hoot and look great. they are racing the real boats in china on Nov.8-10. check them out it is stock cars on water. for the reverse flex shaft here is what you need. Craig
http://www.funrcboats.com/ProductInf...d=FRCBDC1563S2
Team Westerlund Racing
Image Gallery Ŧ UIM XCAT World Series Powerboat Racing Official Site
here is the other half. if you build one please post pics here. it builds just like a maxcat. will be very cool on two outboards. Craig
xcat race in China. fantastic. check it out.
http://www.youtube.com/watch?v=wJVkx...edium=facebook
http://www.youtube.com/watch?v=5ZLYw...ature=youtu.be
hi all need some help. an friend thinks I am lite on my motors. here is my setup. 3660-2050kv aquastar, 120amp turnigy esc, 7200amh 40-80c lipos. hull with everything is 12 pounds. two pro boat outboards. I need motors to fit these??? /thanks Craig
Hi guys here is the maiden run. it is a great running. but getting hot fast. end weight was 18 pounds. so the setup is weak. not that good with electrics. anyone got an idea for a great setup. could use some help. Thanks Craig
https://www.youtube.com/watch?v=wrK0...ature=youtu.be
Hi Axel I got some cnc props from offshore electrics. 38mm and 42mm. I used the 38mm first. ran with 4s 7200MAH 40-80C LIPOS. AFTER A MIN THINGS GOT VERY HOT. SO NOT SURE IF i NEED MORE MOTOR. OR MORE MORE CELLS?? WHAT DO YOU THINK. cRAIG
Craig i think its a question of adjustment.
can you make a Foto from the side with the hull on a plain hard surface so that i can see the angle of the outbourd and the running height .
It looks that the OB is so mounted that the props are full in the water.
Hi Axel
here you go. I mounted the ob even with the bottom. I am pulling the motors to night and plugging holes. sat. I will move the ob over a 1/2 inch. do I need to move the props up???
Craig you will be running in a circle. For 19lbs you would need the power of about at least 4-5 KW and you canīt put that thru the OBīs because you are limited by the Flex in the OB and the Propsize.
The best chance i see is using 6 S and motors like https://www.hobbyking.com/hobbyking/...?strSearch=h31 or
https://www.hobbyking.com/hobbyking/...arehouse_.html
take care
Axel
take care
Axel
