Traxxas Spartan Motor bearing size
ive got a traxxas spartan and the motor got wet and the bearing rusted i need to replace them what size are they and any good recommendations?
can anyone help me with my spartan? i decided to take it out today and plugged in the stock nimh batteries and all it does is beep and flash green. the rudder turns but no throttle. after trying to re calibrate the esc and re bind the radio the esc felt a little warm. i have no idea why its not working. this would be my first time taking it out in the water since i had it. couple weeks ago it worked when i plugged the batteries in and now it wont. just a steady green light on esc and flashes every second. and when i pull the throttle to full the beep stops until i release. any help will be appriciated. Thanks.
The only thing I can think of other than sending it back is, one with the power off can you turn over the motor over by hand? Two is the esc voltage cut off set up for the batteries that you are using?
Well I just figured it out. My tq high output 2.4 ghz radio wasn't working. I synced my tqi radio for my tmaxx 3.3 and everything is all good. I then resynced the factory radio to the boat again and just the servo works and beeps. I am still going to contact Traxxas on Monday to see why the original radio isn't working. But I also had that radio synced to my jato 3.3 a couple of weeks ago cause I don't have a radio for it at the moment. Maybe had something to do with that.
