Go Back  RCU Forums > RC Boats > Speed - Electric
Reload this Page >
Boat leaning to right
Speed - Electric For all your electric boating needs.
Old 12-27-2014, 05:44 AM
LADI2000
Exclamation Boat leaning to right
Hi, guys
So I was making this boat for 2 years. It has two 540 size 60amp brushless motors, 8400mah lipo 3cell battery, two 70Amp esc and 2 left turning 30mm props. Than 2months ago I finished it and made a test run. And as soon it came on plane it leaned to right.. So I added weight to left side. But no effect. So i ordered 4 flaps . I mounted them and adjusted them so that boat should now lean to left. But no effect. What should i do, because i can't do more that 1/4 of throtlle,because it leans so much it wants to roll over.
Any ideas would be helpful.
If you have questions feel free to ask:
ID:	2058037   Click image for larger version
ID:	2058038   Click image for larger version
ID:	2058039   Click image for larger version
ID:	2058040   Click image for larger version
ID:	2058041   Click image for larger version
ID:	2058044   Click image for larger version
ID:	2058045   Click image for larger version
Old 12-28-2014, 02:44 AM
mfr02
Isaac Newton - "Every action has an equal and opposite reaction". This is one reason why many twin screw boats have counter rotating props.
Old 12-30-2014, 07:49 PM
Got RPM
Got RPM's Avatar
That hull shape is highly susceptible to torque roll, which is what you have. As above, change one motor to right handed rotation; you will need a right handed prop the same size as the other one.
