Speed - Electric For all your electric boating needs.
Leopard Motors ?
Reply
Old 08-15-2017, 07:06 PM
  #76
JasonWalters
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Leopard motors
Leopard motors what's the difference between a leopard 4092 in a 4082 what's faster
JasonWalters is offline
Old 08-15-2017, 08:16 PM
  #77
kennethfunk
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The 4092 is 10mm longer than the 4082,giving a little more power,depending on what brand too,my Revolt 30 doesn't really need more torque though,it's not big enough at 30 inches,..I have to be easy building speed with the 4082...but would be fun to try the 4092..: )..lol
kennethfunk is offline
Old 08-15-2017, 08:26 PM
  #78
kennethfunk
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Patrick125 has tried the 4092 motor!
Old 08-16-2017, 03:56 AM
  #79
Got RPM
Got RPM's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Cool
For most uses, motor length makes little difference. It is motor Kv that matters the most here. If both motors have a Kv of 1700 they will both be very similar in speed with the same prop. The longer motor will be able to spin a larger prop and may thus be faster. But the higher speed means higher amp draw and shorter run times. And a higher risk of burning up your boat.
What will you put these motors in? What voltage? What Kv?
Got RPM is offline
Old 08-16-2017, 07:29 PM
  #80
kennethfunk
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Good explanation Got RPM: )...I'm using a 1600kv 4082 Goolrc motor in my Revolt 30...working great!!
Old 08-24-2017, 03:17 PM
  #81
Patrick125
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I my experience the bigger motor makes a difference.
I have try the leopard 4092 1730kv, and the 2080kv. Those motors are monsters.
I though the aqua craft 1800 revolt motor was nice and it is nice. The m545 octura prop made a hugh difference on 4s in my revolt.
But the 1730kv leopard 4092 on 4s with the m545 is like going 6s on the stock revolt motor with the m545. The difference was that big for me.
And the 2080kv 4092 is like adding an extra cell to the 1730kv.
These motors are monsters.
Patrick125 is offline
Old 08-25-2017, 11:49 AM
  #82
Got RPM
Got RPM's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Cool
Quite the apples and oranges comparison, and off point. A 4092 is far bigger than a little 36x60 mm RTR motor, diameter and length. No wonder it is more powerful. The poster asked about the difference between a 4082 and 4092, not a little RTR motor...
Got RPM is offline
Old 08-25-2017, 12:55 PM
  #83
crapshooter
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
actually a good 36 mm motor will out perform a larger 40 mm motor. t.p. versus neu.
crapshooter is offline
Old 08-26-2017, 04:50 PM
  #84
Got RPM
Got RPM's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Show proof that a 40x92 TP will be out-performed by a Neu 36x60 motor. Oh, that's right, you can't!
Got RPM is offline
Old 09-18-2017, 10:11 PM
  #85
JasonWalters
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
im putting the motor and esc in a traxxas dcd 41. I'm gonna run a 180 esc. Im also using piano wire as a drive system amd no more flex cable less binding. Batteries are 5000 mAh 50 c rated. So what prop amd KV motor would you run I want it fast.
Old 10-08-2017, 09:36 PM
  #86
JasonWalters
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
What will you put these motors in? It's going in a 41 inch traxxas dcb with a 180 amp
esc running 50c rated batteries. Prop 545. 1730kv
Old 10-08-2017, 09:37 PM
  #87
JasonWalters
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ok thanks
Contact Us Archive Advertising Cookie Policy
