Speed - Electric For all your electric boating needs.
Can I make this toy boat actually decent??
Reply
Old 06-27-2017, 05:38 PM
rampking
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Can I make this toy boat actually decent??
Can you guys give me some suggestions on what to do with this boat? I build crawlers, Help!! This thing doesn't even have a rudder, can I add one? I want to put in everything hobby grade.....surely someone has done this before....Any links or pointers???
ID:	2221869   Click image for larger version
ID:	2221870   Click image for larger version
rampking is offline
Old 06-30-2017, 04:10 AM
Got RPM
Got RPM's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
This is a pit into which you will toss excess money you don't need nor want. The hull will perform poorly with much power and is brittle so it will shatter if hitting anything hard. Can't tell how big it is, but using hobby-grade motors and ESCs, re-engineering the drives and steering etc. will be a lot of cost and work. I strongly recommend that you run it as is and save up to purchase a better boat worth all the trouble.
If you decide to go ahead with this, I am afraid I have little in the way of suggestions for power. 28mm motors running on a single 4S pack, 50 amp controllers, a rudder hung off the transom with steering servo. Sorry.
Got RPM is offline
Old 09-10-2017, 12:03 AM
cablecar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
For less Cost, I suggest using 480A Water cool Brushed ESC for existing 2 brushed Motor, Add Water Cool Ring to Existing Motor.
Keep using existing Drive system. Just add a servo and Middle Rudder. Running is 2S LiPo is fine enough.
cablecar is offline
Contact Us Archive Advertising Cookie Policy
