Go Back  RCU Forums > RC Boats > Speed - Electric
Reload this Page >
Nedding Advice
Speed - Electric For all your electric boating needs.
Nedding Advice
Old 01-12-2018, 05:09 PM
eagle927
Default Nedding Advice
I have a 20 mono hull and a 20 road runner rigger hull I am turning in to Electric need advice on motors ESC this is what I have now.
Brand: Racerstar
Item: 5900KV Motor
Waterproof Level: Splash-proof
Features:
- 4 pole 12 slot hi-torque motor design
- CNC machined 6061 T6 billet aluminum heatsink can
- High purity copper windings maximizes efficiency
- High RPM ABEC 5 oversized bearings
- Universal fit, fits all 1/10 brushless cars; multi-mounting system for M3 screws
- Precision balanced rotor, smoothness for best reliability and maxium RPM
- Stator- super thin (0.35mm) laminations
- Removalbe/replaceable rotor
- Precision engineered for maxium energy coversion
Specification:
Watts: 900
Max Voltage: 8.4V(5900KV), 9.6V(5200KV), 12V(4300KV), 13V(3900KV), 16V(3100KV), 22V(2300KV), 24V(2050KV)
Max Amps: 107A(5900KV), 94A(5200KV), 74A(4300KV), 69A(3900KV), 56A(3100KV), 41A(2300KV), 38A(2050KV)
Rotor Poles: 4
Max RPM: 50000
Length: 50mm
Diameters: 36mm
Weight: About 180g
Shaft: 3.17mm
Length of Extend Shaft: 15mm
Connector: 4.0mm Gold
ESC is Water-cooled 70amp
Thanks for the help.
Old 01-13-2018, 06:39 AM
Got RPM
Got RPM's Avatar
The motor is totally unsuited for your .20-sized boats. The Kv is far too high, and the amp rating of the ESC won’t last thirty seconds with that motor - but it might work with a reasonable motor.
An excellent motor for your applications is the ProBoat 3650/1800Kv offering. You could spend less for a HobbyKing motor with the same specs, but the ProBoat motor is well proven. Running on 4S packs with at least 5000 mAh of capacity it will spin props from x440 to m445. The ESC might work if the boat is set up pretty loose.
Old 01-22-2018, 03:52 PM
jollyroger
Gonna be tough getting a 4S 5000 pack in that hull along with motor, ESC and rxcr. I have a BBY 20" off shore and have a Feigao FG5408408 motor/4761KV and will use a 2S pack for it. The motor was originally bought for an out rigger hydro from plans that was published in RC Boat Modeler magazine, that I never finished. For prop I have an Octura X445 and Grim Racer 42X55.
I would advise getting with the people at Off Shore Electrics . They also have a great forum for fast electric boating. RC Boats by Offshore Electrics
Old 01-23-2018, 10:37 AM
Got RPM
Got RPM's Avatar
I run 5000mAh packs in both my 21” Crackerbox and JAE21 outrigger. Plenty of room. Without knowing the OP’s hulls well it is hard to say.
