Building Genesis from Hobby King
Hi,
I just have the most fantastic help with my Atomic boat who got to hot at the ESC. I have read everything also the "threats" at the top and have should come in these forum before i buy any boats.
But I have bought a Genesis from Hoppy king with preinstall motor.
I have bought all parts now and are now afraid for it not will work, so I need some advise about the setup i got now, before i make the boat and test.
Specification
Genesis boat hull length is 36"
SSS 3674/2075KV motor Max. Volts 30, Max Amps 73, Max Power W 2200
Turnigy Marine ESC 150A - Continuous Current: 150A, Burst Current: 900A, LiPo Cells: 2-6S
2 pc ZOP Power 11.1V 5000mAh 3S 60C Lipo Battery I will serial connect so i got 6S.
After what I can read in the start in these categorize is a little bit overkill, but is it totally wrong and if so, what shall i change to do it correct?
I have bought lot off extra water intake, so the cooling will not be the issue.
Specification
