Electro Vee Help ...
VA
Hi,
Picked up up two Electro Vees from an estate.
Older setup, but I want to get them going.
Looks like it was set up for two battery packs since there is velcro on each side.
Anyone have any idea what batteries I should run and what splitterI need?
Thanks!!
Thanks!!
Most likely 4S LiPos. Not sure what you mean by “splitter”, a single pack will work, or two 2S packs in series. Prop down a bit, otherwise the extra voltage may fry the brushed motor.
