Aquacraft EP Hammer Thread
#876
RE: Aquacraft EP Hammer Thread
Still waiting to see this guys set up, put you can bet I'll have my digital camera with me for show and tell. thanks guys for your patients but it may turn out to be worth the wait. even if you could tame it down some for more stability. remember I have yet to see it,but this is like someone trying to find bigfoot. 1BADVEE
#877
CA
Well I just got started and moved here from AZ. Just finished some mods on with a super vee.where is the park located?..
I would like to run it..
Dyno Don
Dyno Don
ORIGINAL: chipster009
Wondering if there are any fellow Hammer EP owners in Orange County, CA (Irvine or surrounding areas) that want to run at Heritage Park. There's a nice glassy pond there.
I've taken my Hammer there a couple times. Lots of fun!
#879
MO
After taking a couple of days to read this thread, I've decided to purchase a EP Hammer (in white...blank canvas for painting!). Almost every page makes mention of the Permax 600 motor. Problem is...I can't find one ANYWHERE to purchase. Tower doesn't show it anymore and all of my Googling turns up places overseas only. Anyone know a place in the US that I can order one from? Someone had made mention of the motors from All Electronics (DCM-229 or maybe the DCM-231). Has anyone had any experiences with either of those motors? They are extremely cheap and I know that the DCM-231 is a motor that is recommended as a replacement for the kid's PowerWheels vehicles, so they have a bit of power available to them.
I plan to remove the ESC and replace it with my extra Novak Rooster ESC. I'm sure it's a tad heavier than the stock ESC, but I can't really afford an XRS or a Proboat ESC right now. Would adding an ESC cooling block from Offshore help out in keeping the ESC from overheating (the Rooster is rated at 100A, according to Novak)? The only 7-cell packs I have right now are my 2/3A 1400 SMCs that I built for my rock crawler. I guess I could do the two packs in parallel to increase my runtime, but I'll probably just stick to my 6-cell GP3300 Sub-C. I don't envision the ESC getting too hot running only 6 cells.
#881
ON, CANADA
i would have to agree.. since we were talking about the hammer the brushless one with surface drive came out.
it is much faster and more upgradeable for a small price increase.
check this out. it is the newest version of an entry level fast electric boat.
you won't need to upgrade this for awhile.. and when you do you can use equipment that is more readily available.
http://www2.towerhobbies.com/cgi-bin...I=LXMDJ4**&P=7
#882
MO
That's well over what I was wanting to spend. I'm not looking for a 25+mph boat. I was looking for a cheap, fun and semi-reliable boat that I can easily attain replacement parts for if something happens. I don't think that over twice the price is what I would call a "small price increase" ($110 vs $279). While the Hammer has a subsurface prop, I didn't like the "strudder" of the Shockwave 26 and honestly I don't care too much for the boat's looks. Besides, I'm wanting to have a bit of fun on the water when I'm not doing rock crawling comps, which is where all of my "fun money" goes.
With that, has anyone has any experience with the DCM-231 or the DCM-229 or know where to get the Permax 600?
#883
i dont know if these are equivalent to the permax 600 take a peek if interested [link]http://www2.towerhobbies.com/cgi-bin/WTI0094p?&N=P&P=0&F=MASG3560&L=TRKG0110&C=GHATRK[/link]
#884
ON, CANADA
been doing some searches.. is permax gone??
there has to be a good 600 size motor manufacturer around..
the stock motor is a 21 turn 600 motor. you can allways add cells to get more speed out of it. the stock motor can handle up to 8 cells if the water cooling is working well.
#885
ON, CANADA
can allways use the electrifly motor. it is a 19 turn, 600 motor.(pretty cheap too)
http://www2.towerhobbies.com/cgi-bin...?&I=LXJ766&P=0
it is good for a small increase in speed. i don't have any experience with this motor but it should handle 8 cells when everything is working freely and cool. i know someone ( a crazy guy) running this motor with 9 cells in a high current application and it has lasted a whole season.
#886
MO
When I went to my LHS to pick my boat up last night, I asked them about the Permax motor. They have officially been discontinued. Great Plains supposedly has a near exact replacement, but I don't have the model numbers yet. Those motors start at about $12.
Now, onto another issue. Has anyone had any problems in using a different radio with the stock ESC? I have a 75mhz AM Futaba 2PL and since it has 10-model memory I figured that I might as well use it for the Hammer as well. I took the crystal out of my other receiver and put it in the boat's stock receiver. I could NEVER get the throttle channel (channel 2) to ever trim out properly. So, I swapped out the receiver for an actual Futaba one and tried it again. Same issue. Put the original crystal from the boat back into the Futaba receiver, turned on the radio that came with it and everything works fine. Is there something with the stock ESC not being able to handle digital incrementing for trims?
Oh, and does anyone know whether the stock ESC would work in a **gulp** NQD boat with stock twin 380s? My NQD has my Rooster ESC in it and I planned on swapping ESCs, but I'm not entirely sure that the Hammer's ESC will handle twin motors, even if they are 380s. I'll only be running a 6-cell pack with it.
#887
My Feedback: (81)
VA
ORIGINAL: bugman72
#888
NC
My turbovee esc which is the same one as in the hammer will not trim out with my 2 pl. It dose not like digital trim becouse it works with lots of my other radios like traxxas and other non digital futaba too. IDK
#889
My Feedback: (39)
IL
Hello, every one! Wow it's been a wile since I last posted, little over a year. Anywho, I'm selling my traxxas villain 14.4v (what a slow yacht!) I was looking to get some thing smaller, and less harsh on batteries, with the villain 10 batteries would last me about a half hour [X(] I was looking in to the Hammer because it has nice looks, seems easy to mod, and is cheap. But I do have some questions about it, About that plastic coupler you people spoke of way in the beginning of the thread do I have to worry about that now, has aqua craft fixed that by now( hopefully its been three years!)? And how fast are we looking out of the box? And what have some of you been able to get as far as moded speed goes? And can you fit octura props on it? Thanks for the help!-Rick LTW[8D]
#891
ON, CANADA
the plastic coupler has been replaced with a better quality one.
and ye. i still have a hammer 8)
it has been modified to go slowly now.. i use it to pull in stalled rc float planes now. lol
i tow a tennis ball with about 10 feet of string, circle the plane till i tie it up and drag it to shore. works great with a smaller motor on low voltage to avoid heatups.
#893
ON, CANADA
i don't know how fast i got it too go..it would skip clear of the water on its own wake after i did a few mods..
first i swapped the motor to a 16 turn 600 size motor and swapped the speed control for a 100 amp one.
second i routed water through some copper pipes ziptied to the speed control's heat sink..
deburred and polished the prop shaft where it was wearing.
shaped the openings on the water pickup for increased flow..
put in a 10 cell pack... 8)
collected some airmiles in rough water..
i found it went over backwards a lot in rough water.. even with the trim tabs down so i removed the radio box and baggied all the un-sealed electronics.
that helped lower the cg.. keeps it right side up when cresting a white topped wave.
i don't think there is much more that can be done to the hammer without doing major surgery.. to go any faster you might as well go to the brushless boat with the surface drive.
#895
Just posted a clip of my stock hammer on half a charge
http://www.youtube.com/watch?v=xhqrd0mWNEY
Anyone in the Orange County area wanna get together and run at this pond in Irvine, CA ???
#896
ON, CANADA
here is one done partially like mine..
[link]http://www.youtube.com/watch?v=m5sRAkDWFdM&mode=related&search=[/link]http://www.youtube.com/watch?v=m5sRAkDWFdM&mode=related&search=
something i noticed this guy has a problem with is the rudder wiggle.
there is play in the stock rudder and you need to shim it to remove the play or the boat will wiggle down the lake and wipe out at high speed.
#900
ORIGINAL: caspar21
wish you the best with it. its quite fun!
Thanks. I tried my friends hammer and thats how I got addicted to rc boats. And since the hammer was so cheap I thought it would be the perfect beginner boat.
