Brushless Boat
NH
Brushless Boat
I always enjoyed the ease of having a brushless car, and now I want a brushless boat. I was thinking of getting a cheap rtr or artr boat and put a nemesis brushless motor in, and run it on 12 cells. What are some rtr boats that could handle the power of a brushless motor? I have tried nitro but I am also interested in electric boats. If anyone has used the nemesis motors I am interested in what boat you used it in.
Any help would be GREAT!
RE: Brushless Boat
i have the perfect boat for you its a tunnel hull i run a mod motor a 17 turn and i get 30 mph out of it and it turns on a dime it is black with orange flames ill sell it for 130 with servo let me know its brand new and i up graded the outboard to ball bearings
RE: Brushless Boat
Hey T3Racer,
You may want to look at Fuller's "EL LOBO 3". They even have a brushless ARF version.
[link=http://www.drcwebservices.com/ffe/boats.htm]http://www.drcwebservices.com/ffe/boats.htm[/link]
Video Link
http://www.casrecprop.com/videos/vid...eersQmono1.avi
Video Link
RE: Brushless Boat
Something I'm curious about, how do you select a motor for the specific application? I have a micro (13.3") deep-vee that runs on 400/480 sized motors. Hobby Lobby has "long cans" with 2-7 turns, and "short cans" of 7, 8 and 12 turns. What would provide the torque that a boat prop would require? Thanks,
TD
TD
RE: Brushless Boat
Hey Travis,
Here's a link to fast electric boat calculator software. This will help in calculating your performance.
http://www.rcboataholic.com/fe_calc.htm
Figureing your setup is a bit more complicated since, it's a balanceing act between your motor, prop and hull but, here is an article to get you started.
http://www.rcboataholic.com/building/gear_drives.htm
RE: Brushless Boat
Well, I've tried it, but it doesn't contain the cells and/or motor combos that would work with this small of a boat. I just need to figure out how to add to the database.
MA
RE: Brushless Boat
I would not recomend a rtr boat or and El Lobo 3 for your aplication with rough water. Check out some of the deep vees and [link=http://Fine Design RC]www.finedesignrc.com[/link] of [link=http://Offshore Electrics]www.offshoreelectrics.com[/link]
FL
RE: Brushless Boat
Hello Fellow FE Boaters,
I'm upgrading my brushless setup and i was wondering if anyone knows any tricks for getting BEC out of a brushless ESC at 22.2v. I was considering disconnecting hte positive lead to the ESC (receiver line) and running a jumper form the deans plug (batteries) to the receiver plug with a voltage regulator that runs 6.0v from 22.2v (if i can even find such a thing). Has anybody ever tried this or know anything about it. Any advice is welcomed. Thanks. oh and the reason i need the BEC is because my radio box is about 2"x2"x3" and it already cramped with just a micro receiver and mini servo. I did consider using 123 size NIMH which are rated at 3.0v but that would really cramp the radio box and i might have a problem with servo travel clearance if the batteries were to inadvertently move during a run. The 123 batteries also don't have much capacity and would have to be charged freaquently. Once again any advice is greatly appreciated.
