Cheap Brushless esc
LA
RE: Cheap Brushless esc
Taylor:
What would be a good prop to start with. We are going to build several Phantom 8s from BBY instead of the OvalMaster 21s with 540 7L on 6 cells or 2 s lipos. We are using the 120a esc suggested above. We plan to race in a small pond and there are 5 of us so far.
Thanks!
Ben
Thanks!
Ben
umm a X432 is a good prop see how it gets. if its gets hot and short run times then go for the X430. But if its cool and good run times . then you can either prop it up or keep it at the set up
If you decide to prop it up then go for a x435 or x632
ORIGINAL: Taylor Shaw
We have run ABS Falcon hull's for the previous two year's without much success, (one heat win, 4th overall) they are
available from Astec @ http://www.astecmodels.co.uk/product...election=hulls
The mega 22/20/1e is maybe a better bet for eco and/or the feigao 380s11? or 380l9 off the top of my head...
With regard to esc's please remember that in a boat the peak current will be twice the normal run current. For a rough calc current =60*cell capacity/runtime so for 3000mah cell and 5 mins it is 60*3/5 = 12*3 = 36 amps - so the peak is going to be around 70 amps.
I now have the Feigao 100 amp controllers with watercooling at £55.00 each (not even on their website yet!!).
For Eco this year in SWAMBC I know that there are a couple of Graupner Eco Manta's, some Falcons, and a super phoenix.
#32
FL
Hello Fellow FE Boaters,
I'm upgrading my brushless setup and i was wondering if anyone knows any tricks for getting BEC out of a brushless ESC at 22.2v. I was considering disconnecting hte positive lead to the ESC (receiver line) and running a jumper form the deans plug (batteries) to the receiver plug with a voltage regulator that runs 6.0v from 22.2v (if i can even find such a thing). Has anybody ever tried this or know anything about it. Any advice is welcomed. Thanks. oh and the reason i need the BEC is because my radio box is about 2"x2"x3" and it already cramped with just a micro receiver and mini servo. I did consider using 123 size NIMH which are rated at 3.0v but that would really cramp the radio box and i might have a problem with servo travel clearance if the batteries were to inadvertently move during a run. The 123 batteries also don't have much capacity and would have to be charged freaquently. Once again any advice is greatly appreciated.
TN
hi, all you have to do is plug this regulator into the receiver and then plug the esc into the end of it. >>> http://www.superfastrc.com/boat.html
nothing has to be cut, or disabled, the regulator does it all for you. i run this same unit in my boats.
#35
TN
oh so sry, wrong link. here is the right one >>>> http://www.superfastrc.com/parkbec-5...ing-bec--.html
also, you will need to connect the positive and negative wires to your connector that you have attached to the esc.
if you want a 6 volt version use this one >>> http://www.superfastrc.com/parkbec-6...ing-bec--.html
