where do I lube the motor
RE: where do I lube the motor
ORIGINAL: bayani919
It says to lightly oil the drive shaft bearing, where is that if im looking directly down at an sv27 motor?
FL
I have just taken the motor from my SV27 apart. My motor did have two bearings. It only has one working bearing now! The bearing on the output shaft disentegrated. Oil your bearings!
