Making a small cat, (need help getting speed)
#151
RE: Making a Micro cat, (shaping the almost done)
thanks
i have never fiberglassed anything befor can you give me some tips
also where did you get your flex shaft from
#152
neither had i before this.
Always cut out the shape you need before you start and make sure it fits. Put a thin layer of epoxy over what you are laying it on, then place on the fiberglass and use a brush to gently work it in and add some more epoxy resin if needed but dont go mad.
#154
i got it from astec models, as they are in the uk. They do ship wide world i think. Also offshore electronics is good.
One thing i would like to add though is this. If things are as expensive where you are as they where over here, it may end up cheaper to buy an abs hull. Unless you just want the fun of building. Just a thought
#155
i have already got a kyosho twinstorm but i like to build things so i think il make it out of foam. im only 15 so i dont have that much money but i can make the things like the rudder. I was also thinking of making the flexy shaft from piano wire but im not sure yet. thanks for your help
#157
there are some on this site but when i get home i will post sme more for you.
#159
hey sorry my computer broke so i cant upload any photos also, i just started to refurbish it, as i stripped all the paint off and am doing it again for a better finish but when my computer is working i will post some.
