Need some help on my SV27
IA
Purchased new SV Saturday - first run was ok - second run was decent but it started to twitch - today I can not even do a range check and the motor will start running - have had some water in hull and had some in radio box - took everthing out and let it dry
I just tried a new radio FM Futuba 3PM - I have the steering servo working - it will beep once when I plug in the batts - but it will not arm after I hold in the throttle - is there anything I need to do with the Futuba radio ??
thanks for the help
coop
thanks for the help
coop
IA
RE: Need some help on my SV27
Ryan -
Just tried it - I put the trim at nuetrul for throttle - when I plugged in the batts it kept beeping almost like an alarm
then I put trim in the negative and it did the same thing
coop
coop
ON, CANADA
As far as I know the beeping means the trim is in the wrong spot. Keep playing around with the trim. I have mine set WELL in to the negatives.
Make sure you reset it as well by unplugging batts for a few seconds
Ryan
Ryan
IA
Ryan -
I think I just got it - after what you told me made me look at the servo reversing function - changed the direction of the servo and it works - but proves to me that the Aquacraft radio has something wrong with it
thanks for the quick reply and help
coop
coop
