BJ BL cuts out
CA
BJ BL cuts out
how do you stop the BJ BL from cutting out at full throlltle???
i did not have this problem with the stock radio
i have just switches radio's to one that has EPA
is this the problem with it cutting a full thro.
is the EPA adj. too far?????
and with this new radio i get more steering and now it hook's real bad
but i can adj. that out
its the full throl. cut out i cant deal with..
HELP!!!!!!!
its all stock....
running 4500's
oh and turn fins or NOT on a stock boat????
if they were off maybe it would not hook as bad
just slide a bit????
any help would be great
THANX
HELP!!!!!!!
its all stock....
running 4500's
THANX
CA
RE: BJ BL cuts out
How many cells are you using? cuz I've used 14 cells with 4500s and I have the same problem. One idea I currently have is to try a bigger prop, maybe 42 mm. Some folks have tried it and the esc had stopped cutting off the power. I've tried an x440 but that only increased the speed a bit and didn't fix the cut off stuff.
I would leave the turn fins on cuz this isn't a very wide cat.
CA
RE: BJ BL cuts out
These are my ideas(I recommend checking the temps after 30 seconds of running each idea):
•try a 42mm prop
•try a different esc(at least 45 amps cont.)
•try 14 cells
•try a 42mm prop
•try 14 cells
CA
RE: BJ BL cuts out
bump
well this thread is 20 days old from last post.
there must someone that has the same problem and cured it
it did not start cutting out till i changed to a new radio (2PL)
Thanx
Thanx
CA
RE: BJ BL cuts out
cheap cells meanning what????
the cells i have are not the cheap ones, but they are not the best either.......
didnt have this problem at first
20 or so runs then i changed to a new 2pl
and now it cuts out
would a new esc cure the problem????????
or better battery's???
not really ready to switch to lipo......
thanx
and now it cuts out
thanx
ME
RE: BJ BL cuts out
Can you switch back to the old radio system and see if it still does it? That would eliminate the radio as the problem.
If it is the radio, head over to the radio threads. They could help you solve the problem better.
http://www.rcuniverse.com/forum/forumid_157/tt.htm
RE: BJ BL cuts out
ORIGINAL: nuts5000
HELP!!!!!!!
its all stock....
running 4500's
THANX
HELP!!!!!!!
its all stock....
running 4500's
THANX
CA
RE: BJ BL cuts out
well its been awhile scince i have been on here...
but the little programing card from proboat
solved the problem..
thanx to who ever posted that would cure the problem...
