Gtaupner 3966 speed control
FL
This is a servo operated msc with 4 microswitches-the problem I have is figuring out where the battery cables are soldered onto the switches on the battery side of the unit.This unit was supplied with the old Electro Vee boats.If anyone can provide a picture or diagram of the wiring it would be a great help to me and much appreciated!
PA
RE: Gtaupner 3966 speed control
I have the instructions you are looking for..
Let me try try to get these in to a pdf file and I'll attach as a image..
Moppie
Moppie
FL
Thanks Moppie but the instructions do not show me where the battery leads attatch to the microswitches-I need a pic or diagram showing the wires on the side of the unit with the white colored switches.
FL
Well,I have since acquired 2 ESC's that will handle 12 or more cells so I don't really need the Graupner but it would be cool to fix it just for the h*ll of it.I have it working on one speed but can't figure out the series wiring for top speed.
