If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Results 1 to 11 of 11
  1. #1
    Join Date
    Apr 2008
    ottawa, ON, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Still not in the water
    Hi - Got my ESC prog-card USB link and set up ESC for correct cut-off for the li-pos (3.2 V per cell) but managed to blow the crappy drive train (3rd picture) - I always figured it had to be up-graded - The motor shaft is 4 mm and a 4 mm straight steel shaft down to the prop (shown 1st pic) - I have one of these (2nd pic) coming in but I believe alignment is critical for all to work well - Any suggestions - It blew when I was checking to see if the prop spun the right way (which it does'nt) - How do I fix that ? - Thanks All -
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	979174   Click image for larger version.
ID:	979175   Click image for larger version.
    Steve from Danford Lake
  2. #2
    Join Date
    Jun 2006
    va beach, VA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Still not in the water
    just switch 2 wires on the motor and it will spin the right way
    uh yeah..what was i saying???
  3. #3
    Dreamin Hemi's Avatar
    Join Date
    Nov 2004
    Milton, DE
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Before you ask WHICH two....dosen't matter. ANY two.
    -Scott
    These opinions expressed here are my own and may not necessarily represent the views of RCUniverse.com
  4. #4
    Join Date
    Apr 2008
    ottawa, ON, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    OK - No problem with switching wires - motor spins counter clockwise now - Any great ideas on how to get this drive set-up so it's dependable - Thanks
  5. #5
    Join Date
    Jan 2004
    Sneek, NETHERLANDS
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: Steve441
    DON'T run it with the coupler installed as in the picture! It will most likely hit you in the eye..., or blow a hole in the hull.
    The allignment must be near to perfect with this kind of coupler!
    Regards, Jan.
    Boaters are nice people.
  6. #6
    Join Date
    Apr 2008
    ottawa, ON, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Thanks Man - LOL - Now you tell me - I was setting up my ESC and the motor screamed up to full RPM when the plastic drive dog broke and put a nice dent in the ceiling where it hit - Lucky I was not watching too closely - No wonder that boat is now out of production although it did come with a smaller motor originally. The motor is an Xpower B28 with a 4 mm shaft - I am trying to fix up a wire drive for it - Thanks
  7. #7
    Join Date
    Apr 2008
    ottawa, ON, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    OK - I just checked and sure enough that plastic coupler/drive dog (piece of junk) bounced off the bottom of the hull when it broke - The hull is still sound although the paint chipped off a bit on the bottom - Should I put a drop of Xpoxy Finishing Resin and sand it down good - or what is recommended - Thanks - Steve
  8. #8
    Join Date
    Sep 2006
    Port Hope, ON, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    You will have more scratches than that after you get it on the water but you could use just a drop of ca glue for now
  9. #9
    Join Date
    Nov 2004
    Milton, DE
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    The first ones always the worst! [sm=cry_smile.gif]
  10. #10
    Join Date
    Apr 2008
    ottawa, ON, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    You Guys Are The Best - Ho Ho Ha - Steve
  11. #11
    SV27dayton's Avatar
    Join Date
    Dec 2006
    Centerville, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    yea I was looking at the title of you thread and thinking any one of us could have used it. I got one.
    \\\\\\\\\\ Go fly a boat /////
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
