fiego 540s how many cells
i am just wanting to know if the fiego 540s (small 51mm long) will take 3s lipos okay. from what i have read they are only good to 8 cell nimh or 9.8 volts. has anyone run them on 3s ? thanks
ON, CANADA
RE: fiego 540s how many cells
Motors are not limited by voltage. Motors are limited by current in amps and maximum rotational velocity in RPM. Everything else can be derived.
As long as an appropriate wind is chosen you may run a that specific amount of voltage.
You may want to read the first thread on this forum.
Ryan
Ryan
will order it thursday night with water cooling jacket and prop. going to try offshore electrics for the first time dont know what the shipping time will be. do you think 3s 20c 3300 will have enough amp draw capability on that motor. they are the swang cells
Hard to say, I never had a 540S so I'm not sure about the lipos. This mono we have has been a big learning exp so far! Fun though.
ON, CANADA
THe 540 9L would also work very well on 3s.
I would not use any cells smaller than 4500mAh on a boat larger than 22"
I also would not use a motor smaller than a 540 size can on a boat larger than 22"
You should be able to get away with a 12s on that LiPo depending on how you prop it.
Ryan
Ryan
looked at the 9l but mite be a bit to many amps. trying to keep it to one set of cells because of weight as the batt are in front of the motor and will throw the CG way out.
yea its just they have put the battery tray up the front mite have to look into changing it . if i ran the 9l i would have to run both packs. were it is now puts my cg about 33%
