Speed - Electric For all your electric boating needs.
Unofficial "NQD" Tear into Jetboat Thread
Reply
Old 03-28-2012, 01:45 PM
  #2551
seehuusen
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Unofficial
That's fantastic Shev, I cannot wait to hook up with a few other like minded people!
I am still waiting on the parts I ordered to build the boat, but I already know places where it'd be fun to go One is right off the highway too, at Yandina. I live in Buderim, and know of a few more places around here that would be fun too then there's all the creeks where we go 4WDing at Glasshouse as well I'm sure we'd find somewhere to catch up and have a fun day with the jet boats
seehuusen is offline
Old 03-28-2012, 03:33 PM
  #2552
Stein
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I need the brass bushing that goes on the nozzle that steers. What can I use?
Thanks.
Stein is offline
Old 03-28-2012, 03:42 PM
  #2553
duckdogs14
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I like the Green Hankinator!
Stein: I use the plastic tip off of a bic pin. Just pull it off of the casing and cut it down to size & glue it in place. Works great. And we all have hundreds of pins in a drawer somewhere =)
duckdogs14 is offline
Old 03-28-2012, 05:02 PM
  #2554
Stein
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: duckdogs14
Did you mean a pen? If so what part would I use?
Stein is offline
Old 03-28-2012, 05:40 PM
  #2555
duckdogs14
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Oops! Yes Pen. Bic Pen. This is why I don't havean office job First attempt at adding pictures.
Quote:
ORIGINAL: Stein
ID:	1744016   Click image for larger version
ID:	1744017   Click image for larger version
ID:	1744018   Click image for larger version
ID:	1744019   Click image for larger version
ID:	1744020   Click image for larger version
ID:	1744021   Click image for larger version
Old 03-28-2012, 05:59 PM
  #2556
Stein
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
[quote]ORIGINAL: duckdogs14
Oops! Yes Pen. Bic Pen. This is why I don't have an office job [img][/img] First attempt at adding pictures.
[quote]ORIGINAL: Stein
Thanks for the tip thats a good idea but I did not mean that part. I meant the brass bushing in the middle (see pic below)
Stein is offline
Old 03-28-2012, 06:34 PM
  #2557
duckdogs14
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
My bad. You need a new one of them??? That I can't help you with. DU-BRO hobby parts maybe.
Old 03-28-2012, 07:22 PM
  #2558
sundogz
sundogz's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
If you still have the stock motor, you might try taking it apart and salvaging one of the brass bushings on the ends. They should have the same bore, and might work for a replacement impeller shaft bushing.
sundogz is offline
Old 03-28-2012, 07:25 PM
  #2559
seehuusen
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
then there's this guy's solution, using a bearing in it
http://www.rcuniverse.com/forum/fb.asp?m=9389196
I'd think you only need to do the first picture's mod
Old 03-29-2012, 04:23 AM
  #2560
Stein
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks for all the info I will look at the old motor see what I can get from it. And a bearing is a great idea.
Stein is offline
Old 03-29-2012, 06:19 AM
  #2561
hankinator
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Stein, Good luck finding one. Let us know what you use/find. I lost mine and ended up using a couple pieces of small metal tubing to make a bushing. There is three different sizes that I had to cut and put inside each other to reduce to the proper ID.
Later,
Hankinator
hankinator is offline
Old 03-31-2012, 03:20 PM
  #2562
seehuusen
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I'm curious to know, did BJacobsen ever post any videos of his wicked props and mods in action??
http://www.rcuniverse.com/forum/fb.asp?m=10100922
By the way, got my Traxxas waterproof servo the other day... and I have something at the post office apparently... Wooo HURRY UP PARTS!
Old 03-31-2012, 05:55 PM
  #2563
olliechristo
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi gang, another little video of my first tear off.. second boat finished now, 2 boats is much more fun than 1.. crashes are a little hairy....    some things i learned along the way,, shoe glue can melt the plastic on these boats,, yellow seemed worse than white,, ( i get the feeling the yellow is stronger..) perhaps not... also using a surfboard nose protector is good and an old fork makes a good grate..... http://www.youtube.com/watch?v=Qbs2okdljOU
olliechristo is offline
Old 03-31-2012, 05:58 PM
  #2564
olliechristo
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
sorry, white seemed to melt more.. and in reply to cmsrp on my first vid...... after your comments about crocodiles i was a little more hesitant retrieving my boat :/ hahah
Old 04-02-2012, 04:02 AM
  #2565
SkR8Pn
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi guys, I need to grab new lipos and Im wondering if this motor would run better on 2s rather than 3s? Or will it seem really slow on 2s compared to 3s?
SkR8Pn is offline
Old 04-02-2012, 04:58 AM
  #2566
sundogz
sundogz's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: SkR8Pn
That motor is most suitable for 2S (32560 unloaded rpms). I'm running the 2900kv version on 3S (32190 unloaded rpms) in mine and it has plenty of spunk.
sundogz is offline
Old 04-02-2012, 07:40 AM
  #2567
Stein
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: hankinator
Later,
Hankinator
I got a small bearing and modified it to work. The ID was a little bigger then the shaft so I put a piece if brass tube I had in it and drilled out the nozzle a little to fit the bearing. It will work great. I have a pic but its really blurry so not sure if you can see it good.
Stein is offline
Old 04-02-2012, 03:23 PM
  #2568
SkR8Pn
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: sundogz
Thanks Sundogz,
After a handful of different motors on 3S the 4400kv has been great. Doesnt get hot and gets real good run time on 2200mah/40c 3S although anything after 3/4 throttle is noise.
Id like to drop some weight out of the rig. I figured 2S (2200mah/20c) would be a good start as its roughly 70g lighter than the 3S im using. I'm worried that i'll turn it into a yacht on 2S
SkR8Pn is offline
Old 04-02-2012, 06:17 PM
  #2569
Ratrunner
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
im running a 4800kv motor on 2S and it goes very well.
Jason
Ratrunner is offline
Old 04-03-2012, 09:48 AM
  #2570
Scubaru Steve
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
where are you guys getting screws for your motors? i cant find any narrow enough to squeeze past the jet drive, at the local hobby stores all they have are button head and wont go in straight.any suggestions? id rather not file them down.
Scubaru Steve is offline
Old 04-03-2012, 02:48 PM
  #2571
SkR8Pn
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: Scubaru Steve
I use M3 metric socket head cap screws which wil have a smaller od than the button heads.
SkR8Pn is offline
Old 04-09-2012, 09:12 AM
  #2572
s2k matt
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Im fairly new to this forum and figured id introduce myself and show my own boat project. I initially came across these boats while surfing u-tube watching people run them in the rapids and instantly wanted my own. I found this thread and read through almost every page. I ordered my boat on ebay about 3-4 weeks ago and got my parts from a couple different websites within days after. I finished the boat and was able to run it for the first time this weekend and couldn't be happier with the outcome.
Let me know what you think, I was going for a clean looking boat as well as having the performance without breaking the bank. It runs really good, plenty fast on 3S and 2S is probably more than enough for running in the river.
Here are the parts I used:
-Tacon 2848-380L 2300kV motor
-SeaKing 35A water cooled ESC
-2200 mAh NanoTech 25-50C 2S & 3S batteries
The only thing I have left to do is add some kind of guard for the jet intake as its just open right now.
Here is the boat within a few hours after I got it haha.
Custom Red Bull Paint job and new part instill
s2k matt is offline
Old 04-09-2012, 06:45 PM
  #2573
Ratrunner
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
i love the Red Bull paint job.
i still haven't decided on a scheme for my boat. i removed all of the original painted on decals,
in preparation for a custom paint scheme, but so far it's still juts plain white.
Jason.
Old 04-09-2012, 07:35 PM
  #2574
DashRiprock
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Great looking boat, thats a really nice paint job too!! I would like to do something like that with mine too but i have no idea what i want mine to look like. what kind of paint do you guys use anyway?  im guessing that plain old spray paint in a can is not the type to use for this. i need to read up on that one of these days.
DashRiprock is offline
Old 04-10-2012, 05:15 AM
  #2575
Ratrunner
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
the paints that most people seem to be using are the tamiya PS paints.
i certainly will once i have decided on a scheme.
Jason.
Reply
Display Modes
