Speed - Electric For all your electric boating needs.
Unofficial "NQD" Tear into Jetboat Thread
Reply
Old 10-03-2012, 01:23 PM
  #3051
Wheelnut
Wheelnut's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Unofficial
I have switched to EC3 plugs and I'm very happy with them.
Wheelnut is offline
Old 10-03-2012, 02:07 PM
  #3052
sundogz
sundogz's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: swervyn
TRX connectors for me (on everything!) and yep, had one of those jigs but got sick of the smoke lol, either Mr Jig or 17mm slab of cement sheet!
Unlike EC3's, XL60's and Deans which are rated for 60+ amps continuous duty, the TRX connectors are only rated for half that (30A). If they ever heat up after a hard run, you stand to gain some speed by changing to another type of connector. Heat = resistance = energy vampire.
sundogz is offline
Old 10-03-2012, 02:34 PM
  #3053
seehuusen
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
woooo, what a hoot these boats are!!!
I just ran mine after rebuilding the jet drive this morning, i.e. pull it all apart and grease it up + clean all crud and rusty bits...
The new plugs are really easy to get on and off, but tight enough to not come off at any point I really like them!
I ran my boat hard for all of the 1300mah 3S battery, nothing but the battery was hot! So I assume the grease did it's job keeping it all lubed and it certainly kept most of the water out. So all up, great start to the morning
Now to figure out where I can run the boat in some "rapids", as we haven't had any rain to talk off over the past 2 months (SE QLD Australia)... I may have to go down to the beach and run it when the tides turn (= lots of current)
Cheers
Martin
seehuusen is offline
Old 10-03-2012, 03:22 PM
  #3054
Wheelnut
Wheelnut's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Watch out for thos crocs mate[X(]
Wheelnut is offline
Old 10-03-2012, 04:56 PM
  #3055
seehuusen
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
hahaha, yeah, they are not quite this far down... Although, with the ocean temps going up, they are moving down this way... 1 was sighted about 150km north of where I live...
Australia Zoo is in my region, and currently, the only crocks close by, are those that old Steve caught
Lets hope the fence is being checked regularly... LOL
Old 10-04-2012, 08:17 AM
  #3056
geofrancis
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: seehuusen
i want to see croc vs jet boat ! lol
geofrancis is offline
Old 10-04-2012, 11:17 AM
  #3057
Wheelnut
Wheelnut's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
It would be a two second video. Unless you mean vs crock as in Jet boat running for it's life. Now that would be fun to watch. I have a feeling the croc wouldn't be interested.
Wheelnut is offline
Old 10-04-2012, 02:02 PM
  #3058
seehuusen
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
LOL, where I live, I'd be more concerned about the bull sharks to be honest
I just finished re-soldering all my 3S batteries, as I'm heading to the Gold Coast this weekend and I'm bringing the jet boat!!
Is there a trick to soldering really thick wire? The nano-tech was just OK to solder, but the even thicker wire on the ESC... I had to cut some of it out, to fit it onto the soldering tab... is that normal??
Cheers
Martin
Old 10-04-2012, 02:10 PM
  #3059
Wheelnut
Wheelnut's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Well, at least the Bull Sharks can't come up on the land like the crocs can.
Sounds like you battery connectors weren't meant for the wire your using.
Sometimes the wire is a little big for me as well, but I have always been able to make it fit/work
Wheelnut is offline
Old 10-07-2012, 02:04 PM
  #3060
geofrancis
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: Wheelnut
ork
yea if they get close full power up the bank!
Old 10-08-2012, 03:04 PM
  #3061
seehuusen
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
mindful of crocks and bullsharks, I went to the local fresh water creek on my way to work
I can't flaw any of the hardware I've got in the boat now, it just hammers!
The only thing that keeps coming back to bite me, is my soldering... It lasts for a while, but breaks loose from time to time, never the same one either... is that normal? Are the vibrations just a bit too much for it? is it common? is there a fix? (It is pretty annoying when it happens to battery number 1 of 4... )
I'm going to have to invest some time and grab some photos of this thing in action too, but I'm always boating alone, and controlling both seems a task I can't handle... Any tricks other than a tripod and angling the lens right? Some vids look like they have had the camera mounted on the controller?
Cheers
Martin
Old 10-08-2012, 03:54 PM
  #3062
seehuusen
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
PS. For those looking for new propellers, here's a link I just used on eBay (6 for ~$15) it looks like he has a few in stock too
Old 10-08-2012, 04:42 PM
  #3063
Wheelnut
Wheelnut's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Coming back to "bite" you?? is that a pun?? hehe
I think you are experiencing weak cold soldering connections.
you have to make sure you get both the wire and the connector hot enough for the solder to take. The best thing to do now is to clean off all the existing solder and re-do it.
I wish I was near so I could help.
Wheelnut is offline
Old 10-08-2012, 05:03 PM
  #3064
seehuusen
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
hahaha, got it
thanks for the soldering tips, how hot do I need to get it?
Old 10-08-2012, 05:25 PM
  #3065
Wheelnut
Wheelnut's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
you will know, it's hot enough when the solder is pulled in by the wire and connector tab.
You should pre-tin your wire, I even pre-tin my connector tab. Then hold them together with something like this little helper in the picture, put a little solder on the soldering iron tip for better conduction, then put the soldering iron on the opposite side of the connector tab that the wire is on. Keep the tip on the tab until the solder on the wire melts and is pulled in by the tab that you are heating. Just after this I cool it down quick with my wet sponge. Just wet, not dripping wet. This is how I make sure my plastic connector doesn't melt and I don't like a lot of heat to creep up the wire to the battery either.
This may help also.
http://www.youtube.com/watch?v=2jOIBpN6b2Y
Wheelnut is offline
Old 10-09-2012, 07:59 AM
  #3066
SkR8Pn
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
SkR8Pn is offline
Old 10-09-2012, 08:07 AM
  #3067
SkR8Pn
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hull is painted also...... "Man I'm not doing that again!"
SkR8Pn is offline
Old 10-09-2012, 02:46 PM
  #3068
seehuusen
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
That's come up very neat SkR8Pn
I hope the paint doesn't chip on ya, what kind of environment will you be running your boat in?
My local place is astonycreek = lots of scrape marks, even into the plastic!
I think I might have killed one of my LiPo batteries this morning... LOL
I'm not sure if it's the quality of the battery or the fact that I ran it pretty flat...
Possibly the fact that I'm very trigger happy on the throttle, as in I pulse it like you would with a car/ drift car... The ESC doesn't get hot, obviously, being massive, and the motor is only lukewarm...Opinions?
Cheers
Martin
Old 10-09-2012, 03:34 PM
  #3069
SkR8Pn
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: seehuusen
Cheers
Martin
Thanks mate, Oh i hear ya about the scratches and cracks.... I mainly run in creeks around home, Slaughter falls/The Gap creek. They're getting pretty low at the moment though due no rain. The Sprint isn't actually for me it was a present but due to a missus-understandingsomebody actually meant "hydro plane"! Its a shame due to the effort that went into it but it'll have to go..
So whats going on with your lipo fella? Cant charge it?
SkR8Pn is offline
Old 10-09-2012, 03:48 PM
  #3070
swervyn
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Li-po cutoff set properly on the esc?? That Aquastar has auto-detect or set to your cell count and will shut/slow down when minimum voltage reached (3v a cell) unless you have it disabled?? Not sure how else you could kill it unless its a dodgy one?
swervyn is offline
Old 10-09-2012, 04:17 PM
  #3071
swervyn
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Darn, I thought the trx connectors were rated up to 100A ? Now that I've googled it I find anything from 30-100A. Havent noticed much heat but will keep an eye on them, not sure I want to go through the process of changing everything over!
Here is a good link on connector Amp ratings (2/3 way down page) and also some useful li-po information for anyone who cares to read
http://www.rchelicopterfun.com/rc-lipo-batteries.html
On a positive note the last 4 batteries put through the jet boat has resulted in a total of maybe a teaspoon of water in the hull after 4 runs (which may of entered through the push rod boot as) so am happy to finally run it without it filling with water!. Now to the other issues....lol
swervyn is offline
Old 10-09-2012, 04:35 PM
  #3072
seehuusen
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: SkR8Pn
I've added a pic of the battery to my post above I don't think I'd WANT to charge it...
I somehow don't believe the ESC is setup with a cutoff from factory... and I know I haven't changed it...
Next time I redo the balloon around the servo and Rx I'll make sure to tune the ESC as well (in the mean time I'll just not run it quite that flat... my bad I think)
Quote:
ORIGINAL: SkR8Pn
I work out of Hamilton twice a week, let me know if you'd be keen to catch up an arvo for a sesh sometime
Cheers
Martin
Old 10-09-2012, 04:46 PM
  #3073
SkR8Pn
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
"Yep dont charge it!"......
It may of been a bad pack. The only time i've killed a pack was due to low C rating in a high Amp hungry rig. You'll need to call Hazchem or a bomb squad for that pack....lol
Yeah bud it'll be good to hang out sometime and shoot some roosts..
Ja
SkR8Pn is offline
Old 10-09-2012, 05:28 PM
  #3074
sundogz
sundogz's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: swervyn
Excellent link. Lots of good information in that article.....Thx!
sundogz is offline
Old 10-09-2012, 06:00 PM
  #3075
sundogz
sundogz's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: SkR8Pn
some progress on my build. All Jet drive mods are done.
Your intake protection looks nice, and should do well in a large body of water. But it won't keep out the little pebbles that do the most damage in creeks and rapids. Be sure to keep a couple impellers on hand, or possibly consider installing a grate.
sundogz is offline
Reply
Display Modes
