Unofficial "NQD" Tear into Jetboat Thread
#402
RE: Unofficial
ORIGINAL: ryanwilson277
1. ok thanks i will need to know that but also like do i have to program the rx to tx
4.so how do you grind a flat spot
2. I used a rotary tool with a 1/4" grinding wheel and slowly shaved down till I flattened it out similar to motor other motor that was already flattened. Just be careful the shaft does not rotate.
#403
MD
RE: Unofficial
ok yea the transmitter to the reciever
[link]http://www.hobbycity.com/hobbycity/store/uh_viewItem.asp?idProduct=8338&Product_Name=Hobby_King_2.4Ghz_4Ch_Tx_&_Rx_(Mode_2)[/link]
#404
RE: Unofficial
Ahhh, k. I have no personal experience with that system but if it is like any other spectrum system the receivers need to be bound to the transmitter. With my receiver that came with my dx3r system it was already bound to the receiver, I don't know if the system your interested in is or not. If not, not a big deal. You see that it comes with a bind plug, well that is inserted into the Bat/BND port on the receiver and there should be a button on the transmitter to bind, what that does is look for a receiver with the bind plug in it and connects to it. After that it will be bound till you choose to bind it with another receiver. unless there is a model memory.
#406
MD
RE: Unofficial
actually im going to use this transmitter because it works out cheaper with th shipping costs
[link]http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXARP065&P=0[/link]
do i need to get the tx crystal becuas it says its univailable
#407
RE: Unofficial
you should check around ebay.
http://cgi.ebay.com/Traxxas-TQ-2-ch-...item2303eeb3c1
something like that is a nice radio (if you like pistol grip) and they are everywhere for cheap.
if you like stick radios, can't help ya there. dont know much about good brands and such
#409
BC, CANADA
RE: Unofficial
Waiting on my last order from Hobby King which has my lipo batteries. Other than she is almost ready to run.
ok thanx
btw westbeach did u run yours yet
ok thanx
#411
BC, CANADA
RE: Unofficial
Ryan,
I would stick to the 2.4 GHZ if you can afford it with shipping. My second pick would be the stick radio in post 403? I think. The reason why I left out the pistol radio is the incompatibility with alot of airplane/heli type esc. Which would require you to get an pistix in order for the radio to work with the esc. Unless you got a marine esc then any pistol radio will do the trick!
Pistix -> http://www.offshoreelectrics.com/pro...rod=msw-pistix
#412
RE: Unofficial
Well, my boat turned up today and it didn't last 2 minutes before i stripped it and put the brushless in.
I got these.
www.hobbycity.com/hobbycity/store/uh_viewItem.asp?idProduct=8595
www.hobbycity.com/hobbycity/store/uh_viewItem.asp?idProduct=7377
Bolt straight in, both watercooled, basically i took the easy option lol.
Runs awesome, just need to work on my servo mount then i can setup the water cooling.
I got these.
#413
BC, CANADA
RE: Unofficial
Did you at least charge up the batteries and take her for a quickie before stripping her down?
ORIGINAL: TOA57Y
I got these.
http://www.hobbycity.com/hobbycity/s...idProduct=8595
http://www.hobbycity.com/hobbycity/s...idProduct=7377
I got these.
#414
RE: Unofficial
ORIGINAL: TOA57Y
I got these.
I got these.
#415
RE: Unofficial
ORIGINAL: sundogz
Yeah, that's the motor and esc I recommended to ryanwilson as a bolt-in, but he said the esc was too $$ and someone talked him out of that motor. Are you running it on 2s lipo? As far as the servo, I've hotglued them right to the hull with good success. Just find where it wants to be and glue it in. You can always pry it loose someday if needed.
ORIGINAL: TOA57Y
I got these.
I got these.
#416
RE: Unofficial
Put together a video from yesterday, up at Denny Creek, Snoqualmie, WA. If anyone has any idea where that is. As mentioned in the video info, first part is on 2s and at the song change it is on 3s. Its easy to tell. I have had problems with cooling on 3s, but with the water temperature so cold everything stayed very cool. I feel its a good video for those looking to set theirs up this way. Enjoy...
[youtube]http://www.youtube.com/watch?v=Bx9d1kPunuI[/youtube]
#417
MO
RE: Unofficial
I got the flat spot ground in the motor today. It's a real pain getting it out but I found that one side will come out with a philips head insert (for drivers with a hex head) and the other side if you remove the stator and pushrod you can fit a screwdriver through there. Used my angle grinder to do the flat spot, then reassembled it all and it seems to work great. About to do a bathtub test and then hopefully a lake test soon. Still waiting on my 3s LiPo's...
#418
MO
RE: Unofficial
Alright took a small pond run just because it did so good in the bathtub. And, it works great!! Still no speed demon but I think the 3s will change that. The esc and motor were barely warm if at all, so I'm not going to add water cooling unless the esc gets hot when I get the LiPo's in. I also painted the bottom black, and added a big block of foam into the nose section. Will be painting the top green sometime soon.
#419
MD
RE: Unofficial
this looks cool to have.
[link]http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXMNM1&P=7[/link]
it would be the right size for the jetboat right
btw nice vid etokeyopop
#421
RE: Unofficial
ORIGINAL: nomobux
Sooo .. this is a direct fit replacement set-up ? Have a link on the batts for this one ? I like the easy way .. lol
ORIGINAL: goldswim5
I got the flat spot ground in the motor today. It's a real pain getting it out but I found that one side will come out with a philips head insert (for drivers with a hex head) and the other side if you remove the stator and pushrod you can fit a screwdriver through there...
Etokyo - nice vid, read on...
An observation/suggestion for future movie producers:
Maybe I'm on my own on this one, but I want to observe your videos to see and hear your boat doing its thing (no offense Etokyo!) and don't care for any music masking the sounds of the motor, creek, cavitation, wind, cussing, etc. I expect to hear. I'm more interested in being there with you, hearing how it actually happened, so I can better relate to my own boat(s) and experiences. So you might consider leaving off the music, ....this ain't MTV. But maybe it's just me. [X(] I'll get off my soapbox now!
#422
My Feedback: (81)
VA
RE: Unofficial
Etokyopop,
Nice vid. Looks a little chilly[&:] lol
That really looks like fun. The whole video, I was wondering what you were going to do if the boat flipped over.
So in the end, it did flip over. How did you get it out? What if it flipped over on the other side of the river or a littel down the river?
#423
RE: Unofficial
Maybe I'm on my own on this one, but I want to observe your videos to see and hear your boat doing its thing (no offense Etokyo!) and don't care for any music masking the sounds of the motor, creek, cavitation, wind, cussing, etc. I expect to hear. I'm more interested in being there with you, hearing how it actually happened, so I can better relate to my own boat(s) and experiences. So you might consider leaving off the music, ....this ain't MTV. But maybe it's just me. I'll get off my soapbox now!
I figured it out!
[youtube]http://www.youtube.com/watch?v=u4HW4Pnvst4[/youtube]
#424
RE: Unofficial
"Put together a video from yesterday, up at Denny Creek, Snoqualmie, WA. If anyone has any idea where that is"
Lol .. Whatever posessed you to run at Denny Creek ?? Cold and snow. Been there many times.
#425
RE: Unofficial
quote:
ORIGINAL: nomobux
Any 6c NIMH (7.2v) or 2s (20c and up) LIPO (7.4v) in the 2500-3500mah range will do nicely with that setup.
I have some 2S 5000 lipos .. any probs with that ??
ORIGINAL: nomobux
