Unofficial "NQD" Tear into Jetboat Thread
#551
RE: Unofficial
i would like to add that he was using needle nose pliers to pull pieces of plastic off the hull that were ca'd on. was funny to watch when i heard 'oh ****...' lol
#552
RE: Unofficial
Hello Mr.nomobux , Mr.sundogz and Mr.Wheelnut
This Specfication in Boat (My Friend)
Outrunner Motor Apex 450 Size 3,200 Kv (3mm Shaft) ====== > Very Easy Maintenance
Dragon ESC 40 amp With Cooling Plate
Props Shaft 3 mm
Fiberglass filled plastic propellers
27mm 2 Blade Diameter, Pitch 1.4x27=37.8mm or 1.49"
Resize to 19 mm
Li-Po Battery 11.1 Volt 20C
[youtube]http://www.youtube.com/watch?v=S_Rmg14ymSE&feature=related[/youtube]
Props Shaft 3 mm
Resize to 19 mm
#554
RE: Unofficial
#555
RE: Unofficial
Thanks. Mr.sundogz
Specfication in My Boat
Inrunner Motor Dragon 480 Size 3,000 Kv (3.17mm Shaft)
Dragon ESC 60 amp With Cooling Plate
Props Shaft 3 mm
27mm 2 Blade Diameter, Pitch 1.4x27=37.8mm or 1.49" Resize to 19 mm
Li-Po Battery 11.1 Volt 30C
[youtube]http://www.youtube.com/watch?v=7-lp6MVbW2k&feature=related[/youtube]
and Trim-Tab built by hand made.
APEX 3200KV (model 450)
http://www.fronthobby.net/product-th-237755-1118575
DRAGON Blue 60A ESC
http://www.fronthobby.net/product-th...+Blue+60A.html
Propellers
http://www.offshoreelectrics.com/pro...d=xpo-2bld-3mm
Props Shaft 3 mm
DRAGON Blue 60A ESC
Propellers
#561
RE: Unofficial
if memery serves me right i thank its 6mm . i have done this mod but with a sealed roller bearing and drilled the stater bushing out to 3mm and used the grumpner impeller
#563
My Feedback: (81)
VA
RE: Unofficial
aumsdh,
I was going to ask why part of the intake was sticking out past the rear of the boat, but I see now you said it is a trim tab. Because of the angle of the intake and tab, it doesn't look like it will bend. In your research and development to follow, could you show a couple of videos with variable trim tab settings to see how differently the boat rides?
#565
RE: Unofficial
the ride plate just helps with stability a bit to keep form rocking side to side (whatever thats called)
i run one to protect the jet drive from rocks and such
#567
MD
RE: Unofficial
ORIGINAL: llDemonll
#568
RE: Unofficial
Yep thats the side to side movement at speed . the ride plate does help with that and its good for protecting the nozzle from slideing around rocks.
you really dont need an adjustable tap . but an adjustable nozzle would do wonders
#570
My Feedback: (81)
VA
RE: Unofficial
ORIGINAL: DRAGONFIRE81M
#572
RE: Unofficial
ORIGINAL: Wheelnut
aumsdh,
aumsdh,
#574
RE: Unofficial
Vector steering is a good choice for rescue boats - they (usually) have reverse, can maneuver well in tight places, and have plenty of torque for pushing pricey bobbers back to shore.
And did I mention that I already have the parts from a Viper that I converted to jet? [sm=rolleyes.gif] Begood, Sdg.
#575
RE: Unofficial
Ryanwilson, if you haven't already bought a transmitter/receiver you might check this out [link=http://hobbyking.com/hobbycity/store/uh_viewItem.asp?idProduct=10608]wheel radio[/link]
