Speed - Electric For all your electric boating needs.
Unofficial "NQD" Tear into Jetboat Thread
Reply
Old 02-25-2009, 11:47 AM
  #51
DRAGONFIRE81M
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Unofficial "NQD" Tear into Jetboat Thread
i thank the newer style of the nockoff drive is 2.3 but the older one like the first run are 2mm . the reson i know this is im useing a graupner u-joint on the white one and its a 2mm
DRAGONFIRE81M is offline
Old 02-25-2009, 11:48 AM
  #52
sundogz
sundogz's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yep, 2.3mm drive shaft and motor shaft. But it is a sloppy fit with stock connector that came with mine (larger hole). You can see the connector movement whem it runs slowly, and it vibrates badly when up to speed (that's why I have some foam under my motor - to calm things down). If you were to drill and tap 2 more holes in the other side (opposite existing screws) you could get that wobble out. But I'd rather get a proper connector than to go through that (to small to fool with).
sundogz is offline
Old 02-25-2009, 07:31 PM
  #53
DRAGONFIRE81M
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ok i was wrong . sorry headhunter and sundogz. you wher both right . 2.3 mm is it . doesnt really mater know though . since i put the 3mm in the nockoff drive . if anyone needs a replacement . hit me up .
Old 02-26-2009, 09:30 PM
  #54
beke6874
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Dragonfire, I might be interested in your extra impeller and shaft.
beke6874 is offline
Old 02-26-2009, 11:21 PM
  #55
sundogz
sundogz's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
OK, I know it's been too long in coming, but (finally) here are some movies of my knockoff as taken a couple months ago. This was after I modded the intake, added a 2080KV Turnigy (20x40) brushless motor, a 35A Seaking ESC, water cooling, and a 3s 2800MA Lipo. Fun on the river. Some of the 'motor' sound is the vibration of the off-center motor coupler.
Fun on the river: [link]http://www.youtube.com/watch?v=p2AIA7q6iTI[/link]
Snappy: [link]http://www.youtube.com/watch?v=OFT0pWeOeMM[/link]
I've since installed a 3800KV 396W motor (and bobble heads on the figures) to try out. I'll be sure to post results - should be interesting! I've got to replace that coupler first.
sundogz is offline
Old 03-02-2009, 11:44 AM
  #56
Torran
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi has any one had problems getting boat to plane, can some one post some pictures of
battery housing and were to mount.
Thanks Torran
Torran is offline
Old 03-02-2009, 12:32 PM
  #57
DRAGONFIRE81M
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
nope no prob planeing out . i mount my battery in front of the drive line or with two battery on there side . what is your set up
Old 03-02-2009, 01:26 PM
  #58
Torran
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi i have my battery mounted above motor and jet unit , i am using 3500kv motor with 30A esc on 7.2 battery but have just orderd
li-po 11.1v 2450 mha .
Thanks Torran
Torran is offline
Old 03-02-2009, 02:26 PM
  #59
DRAGONFIRE81M
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
is it a standerd 7.2 . if so the 11.1 lipo will help . your boat needs a deit .
Old 03-02-2009, 09:40 PM
  #60
beke6874
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I've got the same problem. The 7.2 stick pack is just too heavy. I am reluctant to get into lipos because i really don't understand them yet. I tied two 7.2 packs but that was way way too heavy. Has anyone ever tried using AA size batteries?
beke6874 is offline
Old 03-02-2009, 10:15 PM
  #61
sundogz
sundogz's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Dragon is right, those are heavy, underpowered batteries. You need to switch to Lipo's. Personally I think 3s (11.1v) is better than 2s (7.4v) because it's easier on the motor and more efficient, not to mention faster (with the same motor). If you get a good quality balancing charger then you needn't worry about lipo's any more than nicads or nimh. Just follow the instructions, and you won't have any problems.
sundogz is offline
Old 03-03-2009, 05:52 AM
  #62
DRAGONFIRE81M
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
if you just dont wont to make the switch yet . no prob . youll need to run a smaller pack more along the lines of a 1/18 scale like this http://www3.towerhobbies.com/cgi-bin...&I=LXTYW5&P=SM if you run two i beleve youll come in just under the wight of one standerd pack and youll can have up to 14.4v if your setup can handel the volts
Old 03-25-2009, 09:06 AM
  #63
damfurst
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I've been trying some brushless motors in the knock off and thought I would post some pics and results. I did try the 2700kv motor first (purple one). It worked, but was slower than anticipated. I then tried an emp 3200kv on 9.9v and it was a whole new boat. I am finally liking how this boat runs.
ID:	1165789   Click image for larger version
ID:	1165790   Click image for larger version
ID:	1165791   Click image for larger version
ID:	1165792   Click image for larger version
damfurst is offline
Old 04-17-2009, 01:03 PM
  #64
blizzzarddemon
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
hey guys i cant find the tear into anywhere they all say out of stock i have foudn this one is this jet drive
http://cgi.ebay.com/ws/eBayISAPI.dll...tab%3DWatching
and will it work with this motor
http://www.hobbycity.com/hobbycity/store/uh_viewItem.asp?idProduct=4704&Product_Name=KB20-40-15L_3800kv_Brushless_Motor_(FIN)
this esc
http://www.hobbycity.com/hobbycity/s...eed_Controller
and this lipo
http://www.hobbycity.com/hobbycity/s...25C_Car_Lipoly
blizzzarddemon is offline
Old 04-17-2009, 01:44 PM
  #65
DRAGONFIRE81M
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
your set up looks good but you can go to 3s 11.1v if you like . i wouldnt get that hull it dont do very well . ill post a vid of mine with a set up close to what you have picked out . just watch ebay they come in sperts look for the seller mideatoys thats where most of us got them from .
http://www.youtube.com/watch?v=a-Mmp...e=channel_page
Old 04-17-2009, 02:59 PM
  #66
blizzzarddemon
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
so the larger hull wont work as well as the smaller one
Old 04-17-2009, 04:54 PM
  #67
DRAGONFIRE81M
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
its a totaly diffrent hull the cracker is flat which it slids around easyer but it hopes like crazy no speed b/c the drive losses prime . where the jet sprint is a shallow v . but very wide and short witch make for a better jet drive hull
Old 04-17-2009, 04:59 PM
  #68
DRAGONFIRE81M
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
here look on this page where i posted pic before mods where done . http://www.rcuniverse.com/forum/m_65...74/key_/tm.htm
Old 04-17-2009, 05:24 PM
  #69
blizzzarddemon
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
dang i have a nitro hammer got from friend and i have not got it wet ye he only broke it in. and i love the jet drive idea but the crackerbox seems to hoppy and driftiy to be a lot of fun. im also looking for a cheap cheap rc boat for a retrival system im coming up with where the cheap boat pulls fhishing line from shore to the dead boat goes around it then your use a fishing reel to reel in both boats it wont strain the boats motor at all.any suggestions on how to make that jet drive work. im tempted to get it and make my own boat hull out of plexiglass i and lexan. im also tempted to install a brushless jet drive into my kyosho blizzard and use 2 small boat huls like reefracers fill them with insolation foam and use them as pontoons for floats only thing is i dont want to cut up my rare blissard too much
Old 04-17-2009, 05:29 PM
  #70
blizzzarddemon
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
i would love the jet sprint or tear into which is the knock off but i am at college and will be home may 6 and go back to work may 12 and would liek a project to occuply my time when hoem before i work and the cracker is all i can find right now unless someoen has a hull tht the craker jet drive will work in
Old 04-17-2009, 06:58 PM
  #71
blizzzarddemon
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
or if you know a hull that the jet drive will work in that i can get cheap ?
Old 04-17-2009, 09:58 PM
  #72
headhunter23
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
dude buy the ebay ndq fake jet sprint, it is literly the cheapest best way to jet boat, just swap motor n servo n batt with something from 2000's! Any other hulls are completely hit or miss. I've gone through 5 differnt hulls for jet drives, none have worked the way I wanted them too without modding the hell out of them. Heck im lookin for yet another hull for my 28mm kehrer... keep thinking yet another jet villain but i want the hull 4 in shorter than a villain.
Ivan.
headhunter23 is offline
Old 04-17-2009, 11:23 PM
  #73
blizzzarddemon
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
the jet sprint no one has its out of stock everywhere
Old 04-17-2009, 11:29 PM
  #74
damfurst
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I agree with headhunter. I also just shot some of video of my knockoff but won't be able to post it until tomorrow. These pics are of the intake that I modified by opening up & then used a piece of exploded metal for grating. This boat rocks now.
ID:	1182353   Click image for larger version
ID:	1182354   Click image for larger version
ID:	1182355   Click image for larger version
ID:	1182356   Click image for larger version
damfurst is offline
Old 04-18-2009, 05:45 AM
  #75
DRAGONFIRE81M
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
found one so far but its in australia. http://www.stanbridges.com/index.cfm
here one in the uk http://www.zipsales.co.uk/ourshop/pr...at-RC-RTR.html
Contact Us Archive Advertising Cookie Policy
