Unofficial "NQD" Tear into Jetboat Thread
#926
MD
RE: Unofficial
hey if it works u shud make it go up and down. then aim it pretty far up and put ur battery all the way in the front. then ull have a cool jet boat rooster tail!
#927
RE: Unofficial
To get a cool jet boat rooster tail, instead of having the outlet for your water cooler pointing straight out the back, you could angle it up. This is something I'll be looking to do. Mine should turn up today with any luck.
#931
RE: Unofficial
yeah i like thanking out side the box . its called loc-line . been thanking about it for a long time . now all i have to do is come up with a stater vin thats going to be the hard part
#932
MT
RE: Unofficial
Dragon, looks really cool what you've come up with. PM Marsh32 about the stator. I've been trying to duplicate his mod on his NQD but havn't had the time yet. I'll send you what he sent me.
#933
RE: Unofficial
thanks man . ill read over it . I'm working on cutting down some coped 29mm Vin's . fun part is getting the inside curve the same for a tight fit .
I'm thanking on a double bearing on the front so i can do away with the stater bushing
#935
RE: Unofficial
My boat finally arrived today. Will have a stock speed video posted tomorrow, hopefully, for Magnat.
Having seen first hand what we start with, my respect for the mods some of you guys have pulled off has risen by about 1000%...
#936
RE: Unofficial
Starting to suffer from too much choice and information, so I'm just going to ask the question - is this an appropriate combo? http://cgi.ebay.com/Marine-3600Kv-Br...item5639874807
Shaft size aside obviously, it doesn't seem too difficult to turn the motor shaft down to size.
#938
RE: Unofficial
ORIGINAL: SS132OFT
#940
MD
RE: Unofficial
ORIGINAL: DRAGONFIRE81M
if i could figure out how to get an x and y axis i will
#942
RE: Unofficial
ss132 my cheapo 3600kv motor has finally arrived, and fitted tonight. I will be running it tomorrow, hang on, I'll report how it went. Most guys have had best results with a 3200kv, this motor was cheap off flebay so worth the test at $14 (£7) and esc for £10 (£20?)
Couple of question!
I have to now mod my sons boats, I can change the motors without removing jetdrive which will save a load of time and mess, but anyone know is the stock glue/seaant up to the job or will it leak?.
I have made a new mesh intake and done the plate mod, what does that actually do? ( the plate that stick out onder the stator)
Hopefully fine weather and a successful run tomorrow!
Couple of question!
RE: Unofficial
hopefully it wont be pics of that magic blue smoke that is a prisoner inside rc electronics, bit like the smoke featured in Lost, its very angry when it escapes and always costs money, I have a feeling my very cheap motor might expire very quickly!
#945
RE: Unofficial
ORIGINAL: pmdevlin
RE: Unofficial
ORIGINAL: magnat
Next person who gets a Tear into can they shoot a stock vid running in a straight line to check the speed...
I have seen the Vids on youtube but everyone seems to turn too quickly to test straight line speed..
#947
RE: Unofficial
That actually looks like it doesn't go too bad. I ran mine in the sink just to see if it worked when I pulled it out of the box. But that's it, it's now on the bench, gutted, awaiting transplant surgery, once I locate and obtain appropriate organs to make it live again.
#948
RE: Unofficial
ooooOOO HAAA HAAAA Haaa haa! Doctor Frankenstein, I presume.... AH Ha hahaha!
Gotta wonder how many kilos of perfectly good Tear Into innards lurk in the shops and closets of NQD enthusiasts. If someone wanted to push the stock motors to the edge, they'd find a plethora of nearly new motors free just for the asking! WOOooo HA ha haaa!..... [:-]
#949
MT
RE: Unofficial
Lol Dr. Sundog. I think I'll put bolts coming out the side of my twin jet boat since at least the drives came out of knock offs. Though really I took one of the motors (the one I didn't run at all and therefore didn't smoke at all) and put it in a Mini-v. After it got broke in it actually runs quite well that and I resoldered everything. I'm not a great solderer, but sometimes you feel like your grandmother could do better than what comes on the back of those motors.
#950
RE: Unofficial
Similiar.. Thanks...
Thats not too bad for a stock boat.. Although you can see that the stock boat is not proportional as the motor is either on or off...
but it looks alot faster then I would have thought...
